Removing t posts
   / Removing t posts #11
Harbor Freight sells a T-post puller. I think it goes for $19.95. I bought one years ago, and it's by far one of the most useful tools that I have on my farm. It pops the T-post out in seconds. I've tried all sorts of methods of getting them out before I bought it, and it's by far the easiest and quickest way to do the job.
   / Removing t posts #12
Save yourself some time.. get a t-post popper.. TSC sells them.. makes pulling t-post a real breeze...
Soundguy
   / Removing t posts #13
T-Post popper gets my vote too. Like Txdon said, by the time you get the tractor positioned, you can have the post out with a popper. Besides you'll probably run into a few posts that you just can't get the tractor close enough to use.
I got my post popper from TSC. The handle on it is square stock and allows me, if needed, to slide a 5' iron bar into it for extra leverage. I've never had to do it, but I could, if needed.
Go ahead and bribe (beer) a buddy to help you. You can spell one another.
   / Removing t posts #14
i made a small loop of chain in a piece of chain i use on the FEL for T-post work.
passed a bolt through a couple of links.
If you did that and then put a slip hook on to catch the loop in the bottom of the High-lift lifter i think you'd be set.
   / Removing t posts #15
I also highly recommend the Post Popper. The metal plate on the business end is notched esp for t posts. Pulling them is somewhat like a ratcheting motion and very fast. Its also equipped w/ a 1/4" grab hook for pulling other types of posts. The thing is built like a tank and can take lots of 'abuse', like handle extensions for gaining more leverage. Ive pulled *many* t posts so far and a fair number of phone pole type posts and only a few required anything like work to remove. If you have many t posts youll save yourself considerable time over a chain only puller.
   / Removing t posts #16
Hows that saying go? work smarter.. not harder?
Soundguy
   / Removing t posts #18
Probably would mess up the small spade plate attached near the bottom though..
Again.. i don't think you can beat the actual tool made to remove then for ease of use and speed.. especialy for something 1 person can do.. etc..
Soundguy
   / Removing t posts #19
Soundguy
I had to believe he was making a joke. :D
   / Removing t posts #20
I have a T post popper too that I use for hard to get to posts, but my favorite way to pull T posts is with a 4in1 bucket. Just pinch the top and lift.
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
2019 Chevrolet Express 2500 Cargo Van (A53422)
2019 Chevrolet...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
(4) 4" X 4" X 69" TUBING (A57192)
(4) 4" X 4" X 69"...
