removing wood shavings from a attic
   / removing wood shavings from a attic #11
I would use a good shop vac to remove the shavings.
You could put the vac outside and run PVC pipe w/fittings just stuck together and then the hose for the pickup.
For a big removal you could put a 55 gal collection barrel before the vac for more volume.
   / removing wood shavings from a attic #12
Above ground swimming pool vacuum hoses work great, too and are relatively cheap. Also, were dust filters because of mouse poo.
Topsoil Trommel (A57453)
Topsoil Trommel...
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
John Deere 6300 (A60462)
John Deere 6300...
