removing wood shavings from a attic
   / removing wood shavings from a attic #11
I would use a good shop vac to remove the shavings.
You could put the vac outside and run PVC pipe w/fittings just stuck together and then the hose for the pickup.
For a big removal you could put a 55 gal collection barrel before the vac for more volume.
   / removing wood shavings from a attic #12
Above ground swimming pool vacuum hoses work great, too and are relatively cheap. Also, were dust filters because of mouse poo.
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
CATERPILLAR PM622 COLD PLANER (A60429)
CATERPILLAR PM622...
1974 Ford F600 Grain Truck (A56438)
1974 Ford F600...
Kubota L3130 (A53317)
