replacement starter
   / replacement starter #11
I don't understand, Steve. The starter flange has two bolts that hold it onto the flywheel case. The through-bolt is what bolts the motor to the mounting flange. . . I believe from the illustration on Messicks.com. BTW: The original starter had 11 teeth and the replacement has 9. Messicks parts list says that the 9-tooth is fine to use. They may have reduced the number of teeth to give the starter more applied torque to the flywheel.
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
