Replacing sodium dawn to dusk with led
   / Replacing sodium dawn to dusk with led
I don't like the harsh white light of LED lighting. I'm curious how long all this consumer LED lighting will last?
Kind of off topic. I was seeing a thing on RFI from LED auxiliary vehicle lighting, that was causing trouble with mobile radios. Why would LED lighting require drivers that work in the RF spectrum?
Early LEDs had a color temp 5000+...don't like that. But they've changed. Offerings now most common 3000 and 4000. I like the 4000 hue. I'm slowly switch most of my lights to that hue.
   / Replacing sodium dawn to dusk with led #22
I have switched nearly all my house lighting to LED in the 4000K to 5000K color temp range. We can see better and less kWh usage. Only one bulb has failed in the past two years.
   / Replacing sodium dawn to dusk with led #23
I worked with LEDs in the 70s. I don't understand why it took that long to use them for lighting.
When I see those CFLs, I am embarrassed! That was a sad phase away from the Edison bulb!
   / Replacing sodium dawn to dusk with led #24
For whatever reason I seemed to miss the CFL phase. Went from incandescent and fluorescent lighting to LED. I haven't had any issues with LEDs other than cheapo xmas lighting. I blame my wife for that but we seem to just keep adding to that collection and a bunch of extension cords too!
   / Replacing sodium dawn to dusk with led #25
I am a little surprised with those that want to hang on to the old tech heat producing lights vs. moving to LEDs. I admit I don't have experience with the particular ones in question, but the high wattage LED bank lighting I have used is impressive. The heat produced means less energy is being converted to light.
Because HPS isnt really what I would consider "old tech heat producing". Its not like comparing an old incandescent to a LED. The 10k lumens of the LED light this thread is talking about....only uses 20% less power than the HPS. (only reducing heat by 20%)
Or in other words...the HPS only uses 25% more power and makes only 25% more heat than the LED, Which isnt a whole lot all things considered.
Same here. Whole house is an assortment of 5k LED's. Some Cree, some osram, some phillips. Took awhile to find a higher lumen (60w replacement) bulb with 5k temp in a candelabra base. Couldn't find one 4 years ago when I made the switch.
Has been 4 years now, 9 LED's in the basement, 28 main floor, 2 outside porch lights, and 2 in the garage door openers. So 41 or so total. Only had 1 quit so far.
Gov't wanting to push the CFL garbage on us
   / Replacing sodium dawn to dusk with led #26
I don't mind the bright, bright white in homes or yards, but I hate the purple white coming at me on a dark road. Thankfully I almost never drive after dark any moire, but I see it all too often in broad daylight and it still blinds and distracts me.
   / Replacing sodium dawn to dusk with led #27
I like the 6000K color temp, sort of like normal daylight. A lot of folks like the yellower bands. Especially women that like the yellow warmth of 3500K, plus it is more romantic, makes their skin look nicer, etc. We have been using filament like bulbs forever, rubbing sticks together to make fire, and generals living/being accustomed with the old yeller glow at night for many many moons. But me, mark me down for 6000K... bright white, not blue ... light that my old eyes like when I am actually trying to see something.
   / Replacing sodium dawn to dusk with led #28
We have motion sensor LED's at various places around the outside of the barn. That bright white looks like day time out light cannot be beat The HPS light is just not the same. They are also instant on regardless of the outside temperature. Not sure what brand they are as the electrician put them in. But they are way better than the old technology they replaced.
   / Replacing sodium dawn to dusk with led #29
How long will HPS lights last?
I think my electrician told me 20 years ago he installed a 250 watt HPS lamp on pole 23' off the ground.
It sure lights up the place, especially with a little snow on the ground and a full moon.
   / Replacing sodium dawn to dusk with led #30
My big 'ol yard light went up October - 1982 and still does its thing every night. Thirty six years and still going strong on the same fixture - same bulb. If it EVER burns out - - ya know, I'll be replacing it with the exact same thing. It's a high pressure sodium(HPS).
8065 (A55852)
8065 (A55852)
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
