Riggin' for steep slopes
   / Riggin' for steep slopes #1
wasabi
Platinum Member
Cullowhee Mountain, NC
PT2445 and PT1850
Riggin\' for steep slopes
Anybody have any proven ideas for safety rigging a compact to make it more stable on mountain slopes that approach 40 degrees in places. I've heard of filling tires with glycol, adding lower weights and/or widening the wheel base, all of which make sense to me...also, while we're on this topic, are there some rigs that make more sense for such customization than others. Thx, Sabi
   / Riggin' for steep slopes #2
Re: Riggin\' for steep slopes
any thing you can do to lower the center of gravity is good
water or gygol in the tires is good up to a point you only want the tire 1/2 full at max
suitcase style on the front end will help keep the nose down if your pulling a implyment up hill
if its realy steep you might want to think about gettign a track conversion kit
   / Riggin' for steep slopes #3
Another possibility is to add duals to your tractor. Here is a link
<A target="_blank" HREF=http://www.unverferth.com/wheelsys.htm>http://www.unverferth.com/wheelsys.htm</A>
Eric
   / Riggin' for steep slopes #4
wasabi, hi
i am originally from the bernis oberland (Switzerland) and my father worked for Aebi. my first education was in mountain farming and one thing that both the eng. at the agricultural faculty & my dad taught me is that you can make a machine do all kinds of things on the side of a mountain. lower the point of gravety, add more wheels in with and more axels, put stuff in the tires ... BUT ....what everybody is forgetting on this disc. site is the OIL LEVEL. if the engine is not made to have a high enough oil level when you are on an incline (not even all POWER TRAC machines are certified to go over 20%) the lubrication stops and your eng. lifecycle is reduced or instant brakedown can occur.
   / Riggin' for steep slopes #5
I recall a post where somebody had put together an under-slung belly weight for their machine (I couldn't find it again, though).
If you are not planning to us a mid-mount mower, hanging the ballast down under the machine would be a good choice.
- Rick
   / Riggin' for steep slopes #6
Wasabi,
I have been following your tractor quest and am also familiar with the Casiers area of NC. It is just beautiful up there but as you have said it can be steep. Realistically, in my opinion, there is a limit to what a compact tractor can do on steep ground. The general rule of thumb is 15 degrees for side slopes and 30 degrees for going up and down a slope. Exceeding 15 degrees on a side slope just plain scares me to much to do it. I have gone up and down some slopes I think exceed 30 degrees but don’t like it. I use my tractor in the N. Georgia mountains so have some idea what you are up against.
There are several things I would look for to set up a mountain tractor. Unfortunately some of them will not be regular dealer options and that equates into money. I would want a tractor of at least 30 hp with an HST transmission and 4x4. My 21 hp can lack the power for some grades except in the lowest gears and would not make some of them at all with out 4x4. I would look for weight (more is better) and the widest stance I could find. Filling the tires with liquid ballast made a big difference for me. If you can spare the ground clearance a smaller wheel and tire combination would lower the center of gravity. This would be an after market option. I would also have a FOPS type of 4 point roll over protection system made. A heavy skid plate will add weight down low as well as offer protection.
These type of modifications are pretty common with state and county mowing crews and may be a place to get information in your area. With out knowing your property it is hard to say but I had a dozer cut some “tractor trails” allowing access through some of the steeper areas to the more reasonable area.
Good luck in your quest.
MarkV
   / Riggin' for steep slopes #7
Bubenberg,
That is a very good point you make and there is now question Switzerland has some mountians./w3tcompact/icons/eyes.gif
MarkV
   / Riggin' for steep slopes #8
Are you talking about terrain like this?
Egon
   / Riggin' for steep slopes #9
not in the eternal snow but at 9-12,ooo feet and rather steep, very much so. your picture is one major valley over in Valais or Wallis. the next mountain range is already in france and italy
   / Riggin' for steep slopes #10
My father rolled a 14hp Bolens lawn tractor years ago. After that I pulled the rear tires off and took them to a tire dealer that serviced construction equipment. They hand packed the tires with lead oxide powder.
In those days the stuff was put into loader tires to increase traction and lift capacity. The tires went from weighing about twenty lbs each to 150 lbs each. A renter used the little Bolens to mow a couple of acres. He used to pull the thing into the garage and lift the rear to scoot it over to the wall.
After I had the tires filled unknown to him, he couldn't budge the thing. He figured he was getting old and weak. You should have seen the look on his face when we told him the lead added three hundred lbs. to the rear. He had gone from dead lifting one hundred or so lbs. to over four hundred. After the tires were filled that Bolens would go like a goat. I drug trees out of the woods with that thing you wouldn't believe. I think the EPA put an end to using lead oxide in tires.
Before I took delivery of my Kubota I had the dealer send the tires out to be foam filled. It took two people to upright one of the rears. One of them got away from a guy in the shop as he was trying to roll it. It ended up pinning him in a corner. He couldn't budge it. The others had to get it off the wall to release him. Foam filling makes a tire flat proof and adds a lot of weight. I haven't had any problems on the slopes here in West Virginia.
One disadvantage is I'm running ags and you don't to want to run them across a lawn. The extra weight really makes them dig in which is great when that's what you want.
Killbros 260 Seed Conveyor (A56438)
Killbros 260 Seed...
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2020 SAVANA 3500 16FT BOX TRUCK (A59575)
2020 SAVANA 3500...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
