ripper for roots?
/ ripper for roots? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
So I have a new Kubota MX4800 and a Bradco Jaws tree and post puller. It works amazingly well but the biggest hardwood I can pull is 6 or 7 inches in diameter. I can use my subsoiler to loosen the soil around larger trees to get them out but it tend to get hung-up on lager roots.
I have been thinking about making a pointed blade for the subsoiler to cut the roots better. But i came across a homemade ripper on Craigslist for less than i could buy the metal.
I'm going to go look at it (buy it) in the morning. I was wondering what some of the more experienced implement fabricators thought of it. Any chance it will work or will I rip it to shreds?
/ ripper for roots? #2
I think you should have fun trying it out. I've no idea if it is up to the task or not. If inexpensive enough certainly worth the try.
/ ripper for roots? #3
Plan on the resistance of the root equal to trying to split wood 'cross grain". 20 ton is just enough ;-)
Sharpen that blade, and peck away !
/ ripper for roots?
Do the tree sheer attachments produce that much force? Just curious where you got the 20ton number?
/ ripper for roots? #5
I am interested to know how well it works.
Have been thinking about one for my machine.
/ ripper for roots? #6
i have a piece of flat bar that has cut and sharpened notches in it. I push my pallet forks together, tack weld it to the bottom, then push the forks in around the roots using it as a saw and you can rip the roots all the way around, then push the tree over and get up under the root ball. grind weld off when done.
/ ripper for roots? #7
Pics or video of your tree puller in action or it doesn't exist :). Please
/ ripper for roots?
It work ok. A lager blade might actually be better. Haven't torn it up yet. Largest hardwood root that i know I've cut was about 3.5" diameter. Also it would be better if it were set further away from the tractor making it easier to back up to a tree and make a cut on either side of it.
I also posted a video of the tree puller in action. Did not need the ripper for those trees. Search for "tree puller" in the titles.
/ ripper for roots?
<img src="http://www.tractorbynet.com/forums/files/attachments/426472-ripper-roots-20141217_131958-jpg"/> this works for me
Awesome!
/ ripper for roots? #13
its for sale for $650. was just about twice that in steel to make it.
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
Adams Weight Hopper (A63688)
Adams Weight...
Caterpillar Tech Manuals (A63117)
Caterpillar Tech...
213063 (A64276)
213063 (A64276)
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
