Roll pin removal---Any advice or tricks
   / Roll pin removal---Any advice or tricks #31
PB Blaster is good and I use it because its easy to get but I have also used Kroil but Kroil can only be ordered from the manufacturer (well, unless things have changed). I just have been too lazy to order it but now that winter is here I may order some more now. Price isn't bad either.
Google Deal
NAPA sells Kroil now.
larry
   / Roll pin removal---Any advice or tricks #32
Fluid Film is not advertised as a penetrating oil but on Utube a sales guy says it is. Looks good and Kroil looks good as well! I'll have to pick some up. Advertised as getting into 1/millionth of an inch space! That's a heckofa claim.
I found Fluid Film for 10 bux a can free ship 3 can minimum...I bought it...
   / Roll pin removal---Any advice or tricks #33
fluid film is good stuff, and I like it a lot for both lube and protectant but I dont think it is a penetrating oil.. I use Kroil and PB
James K0UA
   / Roll pin removal---Any advice or tricks #34
Last time I tried removing a roll pin, I broke a pin punch, and a drill bit. Ended up cutting the thing off with a hack saw.:laughing: It wasnt important, I just needed to get that thing off in any condition.
   / Roll pin removal---Any advice or tricks #35
James K0UA
I would tend to disagree
Last summer after I had received the free sample of FF from online, I looked around for something to test it on.
The only thing I could think of that was really rusted was my Reese Hitch Receiver, it was an 06 and I had not been able to remove it in at least a couple of years due to it being rusted together.
So I sprayed it, and then forgot about it.
A month or so later I was sitting on the tailgate talking to my girlfriend, and my feet were swing as we talked.
All of a sudden I realized that something was rattling when I hit it, and then knew it was the hitch in the receiver.
I put the tailgate up and low and behold, the FF had broke the rust loose, I had to work the hitch pin a little but the hitch came right out of the receiver.
Been a fan ever since.
:thumbsup:
   / Roll pin removal---Any advice or tricks #36
I find gunk liquid wrench works really well for removing stuck parts.
   / Roll pin removal---Any advice or tricks #37
:thumbsup:
Cool, I have never really tried it as a penetrant, and I know it sticks pretty well, so might give that a try.
James K0UA
   / Roll pin removal---Any advice or tricks #38
I was thinking just as you are thinking about heating the nut to make it expand, except I was heating a hub trying to get the bearing race out. I heated and heated and beat the race and finally gave up. Then father-in-law came over who has a few/many years in auto mechanic. He started heating the race and I told him that does not make sense, he kept heating until it was almost cherry hot. He told me to give it a wack. Lo and behold it started coming out. He hit it with more heat, then I hit it with big hammer again. Not too long later it was out, never heating the hub directly. I told him it does not make sense but I will do it that way next time.
Never had to use heat on roll pins, just punch and PB.
Good luck
forget driving out a bearing race after heating it.. just cut it with the torch.. or even better.. weld it out.
a bead on the face of the race will shrink it and it will fall out. BTDT.. works awesome.
soundguy
   / Roll pin removal---Any advice or tricks #39
   / Roll pin removal---Any advice or tricks #40
soundguy
If you try cutting with a torch, how do you not damage the hub? I only had lots of sparks flying when I tried cutting metal with the torch. I'll have to give the welding idea a try next time too.
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
John Deere 3025E (A53317)
John Deere 3025E...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
