OP
rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 11,466
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Good to know ... I'll probably just go with that first off, and see how it goes ...I went through that several months ago when plumbing my grapple.
As everyone recommended, I used the dump/curl circuit first. The grapple jaws opened and closed just fine but when dumping, the tractor labored, the hydraulics shuttered and you could hear the hydraulic relief valve open. The dump actually slowed down.
Since everybody else seemed to use the dump/curl and they were fine, I thought something was wrong with my tractor. Then I read where someone had actually used the lift circuit so I switched my hoses just to try it. What do you know, everything works great now. The loader dumps/curls/lifts/lowers like it always did which is normal and the grapple opens and closes like it should.
I personally think having curl and closing the grapple available at the same time would be more desirable, but I should know for sure soon enough.
If it doesn't work out, changing it is as simple as swapping the QD's on the loader valve on the lift circuit with the ones on the curl circuit.
Should be easy-peasy ...
