cowboydoc
Super Member
- Joined
- Dec 23, 2000
- Messages
- 6,725
- Tractor
- JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
Amsoil brags about being new classification certified. Rotella passed that test with it's old oil without any modifications. Rotella passed all tests for the highest standards of diesel engines with premium performance specifications relating to API CF-4, Caterpillar ECF-1, Cummins 20078 premium choice, Mack EO-N Premium Plus 03, Mercedes Benz 228. and Volvo VD-3. Mack has the highest standards of any engine mfg. out there and Rotella passed their requirements. Classifications that even your beloved synthetic Amsoil does not hold. Rotella is also certified as a warranty required oil (this means that the oil is ok'd for use for warranty purposes for those people that want to read more into this than I meant) for ALL diesel manufacturers in the world. Amsoil doesn't even come close to that.
They also did a year long study of 185,000 in the extremes of Austrailia. The results were little or no wear, minimal sludge buildup, excellent lubrication performance, and virtually no deposits, oxidation and carbon buildup, excellent soot dispersing, and no acidity.
Rotella also routinely tears down thousands of trucks every year in every fleet to determine wear patterns. A poor overhaul rate is in the 500k range. Excellent overhaul rates are in the 1,000,000 mile range. Rotella engines are always in the excellent rebuild categories.
Unlike you I'm not saying Amsoil is a bad oil. I'm sure it is a very good choice for people if that's your cup of tea. But Rotella is no worse of a choice. When used according to mfg. recommendations, aside from some better cold starting issues and a possible 1-3% increase in fuel mileage you're no better off using one or the other.
