JOHNTHOMAS
Super Member
- Joined
- Apr 14, 2008
- Messages
- 7,724
- Location
- Somerset, Ky
- Tractor
- F2690 4WD RTV X1140 MX5400 HST ZD1211
Yesterday loaded my near new L3901 with grapple attached to front to take to Barlows for blowing front hydraulics fuse problem. Mechanic looked at it on trailer but asked me to leave it till they could get it in shop and find the short that kept blowing the fuse. Should be fixed today for pick up.
As I loaded my tractor on the trailer I noticed it started moving on me!!!! I thought earthquake!!! I'm on a hill and by the time I got the tractor in position on the trailer my truck had started going downhill and went about 10' till it ran into a big 6" high monster rock which stopped the front tire. Yep, in park and emergency brake on.
When I unloaded it at Barlows on near level gravel lot the trailer and truck slid about 2'!
I talked to Gary about it and also mentioned how trailer seemed to be swaying some while bringing tractor to shop. He reminded me of several years ago when I had an Avalanche and was loading or unloading a L3240 and the front tires of my truck lifted off the ground and started sliding until he got in the truck and mashed the brake pedal to keep the truck from moving.
I've been transporting BXs, Bs, Fs, ZDs and small Zs but this is only my second L which is much heavier than the others sooooo it is lifting the front end of the truck when it goes up the ramp onto the trailer which then has little to no real brake griping hold on the ground with just the two rear tires on the ground. I'm posting this as a warning to others with heavier equipment. Don't do it alone unless it's absolutely necessary or have the truck heading up hill. Or a monster truck with lots of front weight which isn't a Toyota Tacoma 4wd. Take someone with you to mash the brake pedal and a helper is handy to work the other side of the trailer when locking the tractor down to the trailer if you can get them out of the truck.:laughing:.
