crazyal
Super Member
So I guess what we are trying to tell you is that you need to get a semi with a lowboy trailer with the disconnecting tongue. Anything less is just unsafe. All kidding aside my triaxle has the double jointed flip down ramps with the legs. If your ramps are the kind that are removable and slide into the side of the trailer I don't think that design would work well. I've never been a fan of jack stands. They seam to fail at the worst times. Either they sink into the dirt or fall over.
What I have done to my jack stands is weld a piece of flat steel to the bottom so they don't just sit on the 4 legs. You can use a 2x or cement block under them but both can break. I used 1/8" diamond plate steel with it facing down to give it more traction to avoid sliding. Even if you don't have a welder it shouldn't cost that much to have someone else do it. Plus once done you will need to paint it and I know Barlows sells great Kubota orange paint.
