Sad day for my B6100 :-(
   / Sad day for my B6100 :-( #31
It's good to hear she is gonna be OK.. I had a Deutz D3006 with a similar problem, but the fingers were worn off, so I had a welder buddy fabricate them out of grade 8 bolts, and I used a grinder for fine tuning. Also, if it makes you feel better, I was gonna replace the clutch and pressure plate too, "while I was in there", as you stated, but my clutch assembly was over $1300.00!!!
Those Germans are proud of their stuff!!!! Heck, the throughout bearing was $41.00!!!!!
Nurse her carefully, she will treat you right!!!
Thanks for the good words. I found the skinny end of my 10mm deep socket fit perfectly into the pilot bushing, then I added some tape on the 3/8 inch drive side for a tight fit of the disk. Worked like a champ, the socket slipped right out with an extension after the pressure plate was attached. Ouch on the $3100 clutch assembly, this was just at $200.
   / Sad day for my B6100 :-( #33
Great job Mike. Many years left in that machine.
Gotcha man, when I had my B7100 apart I found that my ratchet handle was the right size to align the clutch. Broom handle would probably be too big. :D
Kuhn Knight Verti-Max 5032 (A57148)
Kuhn Knight...
2014 Ford F-550 (A55973)
2014 Ford F-550...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
