Snow plowing on soft ground
   / Snow plowing on soft ground #41
The gravel drive solution is simple. Replace your cutting edge with a heavy piece of angle. I did it on my new 90" Meyer Minute Mount with a 4x4x 3/8". You can grade anything smooth in the Fall and Spring. I also have an old 9' Meyer dirt drive plow from the 30's that works great on my "Monster M37".
View attachment 585270View attachment 585271View attachment 585272View attachment 585273
Have you tried it on a gravel driveway? Also does it leave much snow packed down?
   / Snow plowing on soft ground #43
I like using my 6' landscape rake with gage wheels. It seams to clear best with the least damage to the driveway least rock redistribution. The driveway is about 500' of 3/4" crushed rock. Once the backhoe is off the tractor, rake on and set, I can make 3 passes and be going back inside for a fresh cup of coffee.
Chris
   / Snow plowing on soft ground #44
We get the same wet snow rain and thawing conditions early and late season. My plow does the same digs the gravel up. I ride back and forth with the truck plow UP just packing down a few tire tracks for the plow to ride on. That stops most of the gouging into the gravel. I hate raking up gravel in the spring.
   / Snow plowing on soft ground #45
Rear blade with adjustable bush hog gauge wheels. Set the 3pt in float.
   / Snow plowing on soft ground #46
I always thought this setup would be the best for removing snow on soft ground. Pull the pin and let it float side to side as well as float up/down on the 3pt, with the gauge wheels keeping the blade out of the gravel. IMG_1446.JPG IMG_1447.JPG
   / Snow plowing on soft ground #47
While it is not some sort of commercial grade plow, I have had excellent results with my SnowSport HD snow plow. Very cost effective and has done a great job. Simplicity can sometimes be a good thing. I never worry about taking out the gravel on 900' drive and I can push right on up into the yard around the out buildings and never worry about scalping the grass. To look at it, it may seem "cheesy", but it works very well. I had a local welding shop build me a winch frame for it and use a $60 winch I got off of Amazon to lift and lower the blade. All that is required on my pickup is a Curt 2" front receiver hitch.
SnowSport HD Utility Plow | Truck Plows & Snow Blade
This vid shows it working
SNOWSPORT(R) Utility Plows - YouTube
This vid shows how it contours to the landscape
SNOWSPORT(R) HD Utility Plow Testing - YouTube
Here it is on my 2015 Chevy 2500.....
   / Snow plowing on soft ground #48
Nice job, I had wheels on a snowblower once but they still picked up some stones, not as many. I just rake in the spring.
   / Snow plowing on soft ground #49
THANK YOU...:)
I had a piece of 3" angle laying around so I tried this.
Drilled a couple holes in it & a thin strip of bar stock & bolted it all to my York rake.
Doesn't cover the entire width of the rake but seems to work GREAT at not digging up the grass drive down to the barn.
Didn't clear the gravel drive as much as the regular plow on the pick up but also didn't seem to disturb the gravel.
Thank you again.
500BBL WHEELED FRAC TANK (A58216)
500BBL WHEELED...
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
2008 CAT 305C (A53317)
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
