Snow Equipment Owning/Operating Snow Plowing With the FEL
   / Snow Plowing With the FEL #31
RancherSam said:
i didn't know there was a "float" feature on the FEL? Is this specific to certain loaders?
Pretty much all modern (10 years old or so) have this feature.
   / Snow Plowing With the FEL #32
My new B26 seems to work differently as it will only float when the bucket is level on the ground. If I try and put the slightest angle on the bucket, say to scrape ice off of the drive, it will not float and just digs in and raises the front of the tractor, put it back to level and it floats. Kinda crazy isn't it? Maybe I should question my dealer regarding it. :)
The Gotcha Man
   / Snow Plowing With the FEL #33
The Gotcha Man
That is quite normal, mine does the same thing. It has nothing to do with the "float" feature of the valve, but rather the geometry of the whole loader.
   / Snow Plowing With the FEL #34
Mornin Kenny,
For what its worth I have the float feature on my old 1986
MF 1040. So I would imagine the manufacturer came up with this idea some time ago ! ;)
   / Snow Plowing With the FEL #35
My Dad's International 966 (circa 1971) had float on the hydraulics as well. This was a dual-valve set-up.
   / Snow Plowing With the FEL #36
Mike,
I set my FEL level (using level indicator rod on it), because my driveway is pretty much level all the way. Set it on float.
If your driveway is paved and over 1 year old, you won't have to worry about the FEL harming it. Less than one year: you might want to buy a heater hose, slit down one side and slide it over the edge of the FEL.
I still use the FEL at times but my rear blade is great for moving the snow. Cheap, only $250.
Ralph
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
43024 (A59228)
43024 (A59228)
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
