Eddie - I do have to use metal or gray Sched 40 supply conduit to the box by code. Can't mix gray and white Sched 40 or white plumbing PVC piping/fittings. I also found out today that nobody makes a 1-1/2" small radius, non-access 90* el in gray Sched 40. There are some 'special radius' el's, but nowhere near as tight as I would like.
One alternative is to bring the outside LB directly into a 8"x8"x4" PVC or metal junction box and then run sub feeder lines from the junction to the breaker box. Those sub feeder lines within the wall would not by code need to be in conduit. Solves the in-wall mount requirement and conduit bending issues but a junction box requires an access cover thru the wall, something I prefer not to have.
Larstan - according to the specs on www.carlon.com, the 1-1/2" Type LR Conduit Body you describe would save approx 1/4"-3/8" of cavity depth vs the Type LB I now have. That would keep the el within the wall cavity. I was able to find and secure the only Type LR in the entire city (odd, but there are plenty of Type LL which come out the other side), and I have a plan in mind to make this right.
And thanks for the laugh guys. Can't tell you how many times I've had parts all over the store floor trying to make something work with a less than desirable collection of fittings. You get some pretty funny looks sometime. /forums/images/graemlins/grin.gif
