Supersteer - Yes or No?
/ Supersteer - Yes or No? #1
Pacesetter300
mid- Maine
Century 3045
Hi Guys
New name here, just getting in to this. Went to the NH dealer and after showing me a TC33D and it's attributes, I said he forgot one - Supersteer. He said he doesn't order them with Supersteer, they are more complicated, more trouble and more expensive. What say everybody? I don't see a lot about it here either pro or con. Any idea of how much more it is and if he is right or not?
Thanks for looking
Russ
/ Supersteer - Yes or No? #2
I have a TC29 (same size) with conventional steering and find it maneauvers nicely in tight areas. And I do put it in to some tight spots while doing close residential backhoe work. For my situation I have to agree with your dealer. However your situation may dictate otherwise.
/ Supersteer - Yes or No? #3
I chose the Supersteer since it has the Sensitrak clutch. This allows the FWD to be engaged, but only lock up when the rear wheels are slipping. As the theory goes, this is supposed to decrease turf scuffing. I also have a bazillion trees to go around.
/ Supersteer - Yes or No? #4
I have it - aside from the sensitrac (which works great) it sure is nice to have when you get into a tight space.
Nick
/ Supersteer - Yes or No? #5
I know I shouldn't be doing this. But exactly how many trees are a bazillion? And do you get dizzy having to go around all of them?
/ Supersteer - Yes or No? #6
When I inqiured about "supersteer" before buying my TC33D the dealer advised against it if you would be doing loader work because of the extra weight on the front end was not good on the supersteer system??????? He said if your mainly cutting grass it is wonderful.
/ Supersteer - Yes or No? #7
I do not know if it is hard on the supersteer, but when you do a lot of loader work, with a lot of weight on the loader and if I turn real sharp with the load, I have broken the bead on either of the front tires. Of course this is when I happen to be be going over a tree that is laying on the ground at the time. Head back with the partially deflated tire and go again.
You just have to watch with a heavy load in the bucket.
I really enjoy the supersteer as far as mowing around the bazillion trees that i also have.
/ Supersteer - Yes or No? #8
I don't have it and have yet to have a situation where I needed it. I wanted to keep the price down and wanted to keep things more simple. I guess it comes down to how you will be using your machine and how much you have to spend. I have a garden tractor for the tight mowing around the house and I don't have too many trees to maneuver around away from the house.
/ Supersteer - Yes or No? #9
I have it on my 35D.
Once u have it u will use it ALL the time.
I can turn around in a 2 car garage w/o brakes.
Just can't get over how sharp it can turn!
/ Supersteer - Yes or No? #10
Russ,
I did not get it beacuse for my applications it seems unecessary. I have a lot of space to trun around normally. However, I will say that even the normal steering turns quite sharp.
Also in the TN range the S models (ones with super steer) are usually loaded. When I bought my machine the dealer had an almost identical unit on the lot with super steer and a few extra goddies (electronic 3-point, etc..). This was a used machine with ~300 hrs and they wanted several K more than for the new tractor I purchased!
Another concern is the loader. I think you could get into trouble with super steer by turning very sharply with a very heavy bucket load.
So bottom line is it depends on what you are doing; minimal loader work and tight spaces might make sense for supersteer.
Fred
/ Supersteer - Yes or No? #11
I got it - because it was on the sale tractor I bought. Kodiak - a bazillion trees is that number of trees that you have in excess of the number you don't mind mowing and trimming around.
I find it mighty handy - makes it easy to over-steer though. I don't know how the tractor would steer without it, but I expect I could live without it. The Sensitrac, though, is pretty nice. No ... I take that back. It is very nice.
Regards,
Jim
Thanks Jim and everybody for the input.
I visited another dealer this weekend who is a proponent of Supersteer. I tested a used 29 with it and see where it comes in handy. I see it might be a problem doing a sharp turn with a full bucket up high, but I don't envision that circumstance. I totally agree that the Sensitrac is great. My feeling now is I'm buying the Sensitrac and the Supersteer comes with it. There's a deal on the 33's now too. About an extra $1000 off and 0% for 48 months
Nice to be with the group
/ Supersteer - Yes or No? #13
<font color=blue>My feeling now is I'm buying the Sensitrac and the Supersteer comes with it. </font color=blue>
That's the same thought I had. The dealer is waiting for the last rear remote to come in so it can be installed, and then I'll switch to the Owning/Operating column.
/ Supersteer - Yes or No? #14
I have a TC45D with supersteer, and I am glad I have it. One negative is that it easily turns so sharply and when you are going too fast and cut the wheel to turn, it pushes up dirt. It does turn very sharp, but you have to be going slow to "give the tractor time" to turn and not dig up ruts.
/ Supersteer - Yes or No? #15
I tried this while mowing Sat. nite.
Turn full lock out in uncut grass and
mow a circle.
43" diameter w/o brakes which I think
is pretty good.
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
19010 (A55851)
19010 (A55851)
