Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
You apparently missed the very last line of my message.. or didn't read all the way to the last word. my comment was related to the gas engines that have the user operated throttle control that connects directly down tot he carb butterfly.
I'm not talking about the more advanced gas run engine.. .. just the plain jane push mower and other engines that are NON governed... except by your right hand. IE.. I specifically said to follow the cable to the carb butterfly. common sense would dictates that if the user operated throttle cable don't go to where I said. then my comments didn't apply to that application.
soundguy
soundguy
David Cockey said:Gasoline engines made by Briggs & Stratton, Kohler, Techumseh, etc used on lawn mowers, garden tractors, snowblowers (at least those with 4 stroke engines), roto-tillers, etc all have governers. The "throttle" control acutually controls the governer, and the governer controls the throttle plate in the carburetor depending trying to keep the engine speed at the desired speed. The air cooled gasoline engines I'm familar with use an air flap governer, with air from the cooling fan blowing against a flap. When the engine speeds slows down due to load the flap moves which opens the throttle. If the load on the engine is sufficient the governer can open the throttle fully to "WOT".Depending on the type of governer the speed will vary somewhat with load, but no where near the amount it would vary without the governer. Of course if the load becomes too heavy even full throttle won't keep the speed up and the engine slows.
Think of the governer as cruise control for engine speed. As an aside "cruise control" on an HST tractor is really just a lock on the pedal control of the transmission, the speed of the tractor is controlled by the governer on the engine.
I don't know how a string trimmer or chainsaw engine is set up, it is probably not the same as the larger, 4-stroke gasoline engines used on power equipement.
I'm a mechanical engineer, and this has nothing to do with my hat size.
