TC-29 starting problems
   / TC-29 starting problems #21
FarmallAcres said:
I contacted 3 NH dealers and NH in Wisconsin before I found the service bulletin with install steps for starter relay. Purchased the relay with wiring harness and fuse holder for less than $5 at local auto parts. Will install relay next week and post my results. I tried new swith for $105 but did not work. My dealer wanted to replace starter but this discussion board led me to try relay.
Latest update: I installed the relay fix. No problems with install and followed exactly like Mike indicates. With numerous starts both cold and hot, no problems at all. My CNH dealer has a 45hp model in shop with intent to install same relay fix. I recommend all try this. Look for relay and wiring harness on web or at local parts store. Much cheaper than ordering from CNH.
New Holland 650 Hay Baler (A53317)
New Holland 650...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
Cargo Van (A59230)
Cargo Van (A59230)
2010 John Deere 8320R Tractor (A59814)
2010 John Deere...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
