TC55DA vibration on paved road. what is it?
   / TC55DA vibration on paved road. what is it? #21
Hi Roto! Just a little more on the sympathetic vibration. My old NH 1920 did not do this. I can only guess that as other members have said that it could be the wheels and tires are a little out of balance, maybe the sheet metal is a little thinner than in the past and/or other parts of the tractor combine at higher speed to start the vibration and then it starts! Just back off the RPM a little and it helps for me. I think you could eliminate or minimise it if you spent a lot of time and $$ to mess with the different parts of the tractor but it really isn't a problem, just a minor thing to me since I rarely go very far or fast on the road. Good luck! Ken
well i tried different speeds and RPM and still has that same rythmic vibration 4 seconds on and 3 seconds off and i would have to go like 10 mph or less to not feel it. I guess i will live with it but it doesnt seem normal or healthy.
Mike
   / TC55DA vibration on paved road. what is it? #23
Does the frequency change with road speed, or is it constant? By frequency, I don't mean the 3-4 second cycle, but the "speed" of the vibration.
Chris
   / TC55DA vibration on paved road. what is it? #24
Mine acts the same .It gets better the more i drive it i thought it was the ribs on the tires . It is worse if i let the tractor set for a week or two the tires warm up as others have mentioned and it gets better on mine.
well it was a 40 minute drive on the tractor and it did it all the way over and im convinced it would after 500 miles. Not the tires in my case. I find it hard to believe.
Hard to say about the speed of the vibration changing with road speed. I would say only that it is less vibration gradually as i go slower the vibrating is less so maybe at 3 mph i wouldnt notice it but as i go faster i notice it and more intense vibration as i go faster to the point where at 18mph the steering wheel really vibrates bad enough so i feel uncomfortable with it as i dont think it should do that. I still think it has to do with 4wd gears turning and meshing every so often as they are out of sync.
Mike
   / TC55DA vibration on paved road. what is it? #26
I wish I was there to hear it. I love Maine, particularly at this time of year. Sorry I couldn't help.
You may want to check to make sure the 4wd is disengaged.
Chris
you mean feel it not hear it as theres not much sound. not in 4wd for sure i triple checked. anyway, i trucked it back on my trailer and will try to avoid the long paved runs. I will try it on dirt sometime to see if the same effect.
been a beautiful month of August here in Maine. sunny and 80 and dry and clear. I did 7500 40# square bales in the last month and have 127 hours on the tc55 mostly in the last month.
Mike
   / TC55DA vibration on paved road. what is it? #28
Tractors are not designed for on road use or high speeds!
   / TC55DA vibration on paved road. what is it? #29
However.. it's certainly ok to run down the road at a speed the tractor can achieve on it's own.. and except for tire wear.. there aren't many more problems associated than that.
Soundguy
   / TC55DA vibration on paved road. what is it? #30
Roto,
I think most of us are giving opinions thinking this is a typical minor vibration you are feeling. If that's the case I wouldn't worry about it. But when you say it gets to the point of feeling "uncomfortable", I would call a dealer to have them test drive it some. I haven't taken my DX55 on any road yet, but I wouldn't expect it to feel uncomfortable. Maybe a service or sales person can stop by your place when they are out and test drive it for a better opinion. I'd want them to test one from their lot too, just to compare the feel.
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
1761 (A58375)
1761 (A58375)
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
