- Joined
- Aug 31, 2001
- Messages
- 65,912
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
That sounds about like the best solution to me over a flatbed. I admit to only having one slide in bed liner over the years. When I pulled it out to repaint the truck there were rub marks almost to bare metal from vibration. That and as said, the sliding around issue.
If you truly use a truck as a truck, once you have a flatbed you likely will not ever want a stock bed again.
Unloading this load of soggy particle board in the rain by hand would have really sucked.
Dumping in this field stone would have destroyed a regular truck.
And not having to unload anything by hand saves me a bunch of work.
:thumbsup: makes hooking up my gooseneck trailer so much easier. Mine is aluminum and I had it sprayed to keep things from sliding too much.If you truly use a truck as a truck, once you have a flatbed you likely will not ever want a stock bed again.
