Texas Grapple Shootout
   / Texas Grapple Shootout #92
I think that's even compact enough to mount onto a small lawn tractor. I'll see if Ted will work on a mount!! :laughing: Travis
Travis .. That's not anything to laugh at .. I've got a customer that wants me to configure a hay accumulator for the front of his JD Gator
   / Texas Grapple Shootout #94
Contact the Rake Shop, he will build it for you. :thumbsup:
   / Texas Grapple Shootout #95
Ok, I think I found my perfect grapple. It is actually parts from two different ones.
If you end up having one built as xfaxman suggests, you might want to consider a tall opening. I wouldn't consider anything less than 45" if you have the lift capacity.
That reminds me I need to find the lift capacity of my Kubota L5030. 45"+ would be nice!!
xfaxman do you have any dealings with the Rake Shop?
   / Texas Grapple Shootout #97
TractorData says 2,374 pounds lift to full height at the pins, and 1,764 pounds at 500mm.
   / Texas Grapple Shootout #98
No, just have seen it referred to in several previous grapple threads and remembered that on the Website, he said he will custom build.
I would also recommend the largest opening possible, brush is light. you will spend less time moving a lot of brush with a big bite.
For heavy trees or logs the large opening won't hurt, except for the slightly heavier grapple.
Thanks, I knew someone would have it faster than I could look it up. So that means I can get a 764 pound grapple and still haul 1,000 pounds of woody stuff.
   / Texas Grapple Shootout #100
The lid would look like this Lands Pride:
SGC20 Series Claw Grapples | Land Pride
And the base would look like the curved tunes on this Rake Shop grapple. However the tynes would only be 6" to 7" apart and mesh with the lid.
www.TheRakeShop.com / Root Rakes Grapples Attachments & Skid Steers
So, I'm still looking . . . . . . but getting closer. . . . .I think.
Don-I think you are getting close to perfection.
Charlie
Year: 2005 Make: Dodge Model: Ram Pickup Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2005 Make...
2005 Chevrolet C4500 Landscape Dump Truck (A55788)
2005 Chevrolet...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
2000 Ditch Witch 3700DD Ride-On Trencher (A55787)
2000 Ditch Witch...
2010 Cadillac SRX SUV (A55758)
2010 Cadillac SRX...
