Doesn't the torch affect the paint?
No, it did not. Remember aluminum spreads heat out quickly.
Looked really scary to me. Get it too hot, and you're buying a really expensive hood.
... paintless dent removal ....
I wonder if people could chime in on what the satisfaction level is with this technique?
I guess it depends on the paint condition and size of the ding/dent?
I thought the late 1990,s and 2000,s model buick lesabres had the same plastic body panels?We have owned 4 lesabres(1993,2000,2002,2005) and for the most part they have been rust free.I always wonder why more car makers didn't follow GM's lead with the Saturn vehicles that used plastic body panels over a steel inner skin. My '04 L-300 body panels still look like new after sustaining 10 hard Michigan winters. The only complaints I have read about such construction is the wide gaps between body panels...to me that is a non-issue.
Last year we went looking at used cars for my daughter. We looked at a couple Saturns. The bodies has some scratches and actual holes in the corners of the doors where the plastic had cracked. But, comparatively, those holes were no worse than rust holes on a metal body and they weren't going to get progressively worse, either. We were bummed, however, by the condition of the metal under the car. The frames were rotten. So, the cars looked a lot better for other cars of equal age and mileage from the outside, but were just as susceptible to rust underneath. But I sill like the concept. I also liked the plastic bodies on the Fiero's. :thumbsup:I owned 2 Saturns and loved the plastic bodies. Rest of the car was hit and miss.
Chris
I think the bean counters explanation is that anti corrosion advances on steel bodies have brought them to the point that most cars wear out before the body rusts through and therefore, the plastic is not cost effective. Also there are overall weight advantages in using the metal body as a structural component.
My Toyota Tacoma has a plastic bumper, grill headlights, fog lights, and fender flares. I hate it. A turkey bounced off the right corner of the front bumper and under the tire. That bounce flexed the "bumper" enough to break the fog light and headlight mounting tabs as well as the small metal brace behind it. There's ZERO structural support there. It's just for aerodynamics and covering components.
When I hit a deer the inside edges flexed up and down like squeezing one side of a water balloon. So even though the deer hit the driver side of the bumper, it snapped every freaking mounting tab across the front of the truck!I had to replace both headlights, grill is zip tied in place for now, and I replaced the plastic crap with a plate steel off road bumper. It wouldn't be as bad if the plastic dented in and popped back out, but it doesn't. It flexes and breaks everything else it's attached to. Oh, and the dealer quoted me $1900 for just the plastic pieces, no metal, no repair! Just swapping parts. I paid $1,000 for the steel bumper, and maybe $100 for 2 headlights off RockAuto, and called it a day. A year later I hit another deer and just wiped some fur off the winch cutouts.
