This day in 1997, of my house build
   / This day in 1997, of my house build
19970306 Thursday
bad news......
50 mph winds blew down 2 of the back wall sections. My wife found out before me, and was afraid to call me at work and tell me. She told me when I got home from work.
My neighbor saw it, and added more bracing to the left wall to save it.
   / This day in 1997, of my house build #172
Good neighbor. :thumbsup:
   / This day in 1997, of my house build #173
Oh that sucks!!!! Glad that's all you lost!!!!
Ironic. We had 50mph gusts yesterday..... :)
   / This day in 1997, of my house build #174
That's a huge setback. Did you dismantle the lumber and use it again or was the damage too severe?
19970307 Friday
Took off work to repair the damage.
Was able to reuse most of the walls that fell. They weren’t broken too bad.
I pulled them back up onto the 2nd deck with a rope. My dad had brought me a 1” diameter rope in case I needed it. I threw it over the house, tied it to the wall header, and used my truck and pulled them up. I don’t recall how I managed to do this by myself, but I did. I did break the rope a couple times. The rope is still hanging in the back of my shed. My dad gave me some kidding about breaking it.
View from on top.
One section hit in a basement window opening and broke the bottom plate, so that got replaced.
The other one had a few breaks, but was also salvaged. By the end of the day, they were back in place.
At the time I didn’t analyze what went wrong. My theory, looking at the pictures, is when I stood those 2 sections and the left wall the night before, I braced them as always, but I had not nailed them together to each other. The right back section had sheathing attached that would get nailed to the middle section. I had to reach out the window to nail the sheathing that overlapped the 2 sections.
In the end I lost 1 day and a few broken pieces.
19970308 Saturday
Busy day.
Started by attending a church breakfast.
Had help from Don 10 hrs, Stacy 1 hr, Bert 4 hrs.
Installed all rafters on 2nd story except for where the dormers go.
   / This day in 1997, of my house build #177
Nice!! I like it!!!
   / This day in 1997, of my house build #178
It was really starting to take shape by at that point.
   / This day in 1997, of my house build #179
One of the reasons that I like to put on the sheething after all the framing is done is that I can tie it all together for maximum strength. Zip System wasn't around back then, but today you can get it up to 12 feet long, which adds a lot of strength to a house!!! If I was sheething your house, I would have done the first layer on the side, and then gone vertical on the rest so I could tie the lower and upper studs together with the floor joist, and then go up on the next row to tie the gables into the wall studs. When I left CA in 2002, they where requiring homes to have solid metal strapping from the concrete footings to the tops of the rafters, and then the sheething pattern is engineered for maximum strength and inspected to make sure it's done as the plans require before house wrap can go on, but that was with 4x8 sheets like you had to use back then.
I'm not criticizing your build, but just commenting for those that are following and thinking of building their own house or barn.
That was not code at the time, not even hurricane ties. When I built garage and barn the hurricane ties from side to rafters were required. But in a tornado like what hit cookeville TN this week, those ties would not have helped.
Today I would probably use zip board, but many builders still build like I did. In the last 2 weeks a small 1 story house was built just down the road. I can’t tell if they strapped sill plate up to wall bottom plate. Already has the roof covered.
Many houses here built using preassembled wall panels, truck them in, stand them, nail them together.
Maybe I will do another thread of our church building construction that I designed. It used premade panels. We used a GC for it, was built in under 6 months.
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
