Three point hitch slow leak down and hiccups when in use
   / Three point hitch slow leak down and hiccups when in use #11
Use the 3pt arm lock under the front of the seat to see if you even need to take the piston out.
Even with the knob turned all the way to the lock position the 3pt hitch still leaks down. It leaks quite a bit slower but still leaks down. I did notice the hydraulic filter housing is leaking a little at one of the o rings. Could that possibly have anything to do with the 3pt hitch leaking down or is that system closed off or separate from 3pt hitch by a valve or something?
   / Three point hitch slow leak down and hiccups when in use #13
The filter is on the suction side of the pump and would not affect the 3pt.
   / Three point hitch slow leak down and hiccups when in use #14
The valve does two things. One is it regulates the rate the implement drops when the 3pt control lever is pushed forward. The other is that when it is turned all the way in clockwise it blocks off that path entirely and the arms stay up no matter what you do with the 3pt lever.
So if you had closed the valve and the arms stayed up we we would have known the problem was in the path involving the valve and the 3pt control....not the piston. But since it still leaks down it could be either one - or both. I'm betting it is both.
And because closing the valve did slow the leak a little, that tells you it needs attention. I would probably rebuild that valve first. It is simpler to do & usually just involves taking out the valve assembly apart and replacing a couple of O rings, some packing, and cleaning up the orfice.
If you are real careful taking it apart a good cleaning will be all it needs to get dirt & rust out.
It wouldn't surprise me if you still will need to fix a problem in he piston seal to the cylinder - Tractor Tech has already given you some good info on that. Lots of time a leaky 3pt is traceable back to rust in the 3pt cylinder which eats up the piston O rigs and clogs up the drop rate needle valve.
As for the leaky filter, that is on the suction side. It doesn't directly affect the 3pt arms dropping. When the tractor is running is when a suction leak can suck air into the hydraullic fluid. Air in the fluid will make the fluid look cloudy or murky until the micro bubbles go away - usually takes overnight.
Suction leaks don't leak much oil to the outside when running, and small suction leaks don't cause the tractor to operate much different. That is what makes them hard to find. You find them as a small oil leak or more likely as a wet oily connection when the engine is off.
rScotty
Thank you @TractorTech, I was really hoping I was not going to have to pull that piston out because with the cab it looks like it’s going to be a long knuckle busting weekend for $32 in parts. Thanks again!
@rScotty thanks for that info. I know the valve assembly is pretty easily accessible cause I had the seat off today, sheet metal cover removed, and could see the whole valve assembly. While I have it apart I might as well clean that up and change those seals as well. I am hoping I don’t see any rust in the cylinder so I don’t have to replace that as well but that is good info for me to look out for when inspecting everything.
@rScotty Well looking at the MLS valve assembly group, that looks like a whole new can of worms. Not what I thought I saw today when I removed the seat and cover. That looks to be inside the hydraulic cylinder body. They have a seal kit for $72 dollars otherwise I wouldn’t know where to start with that complicated looking valve assembly haha. I wanted to get all the stuff ordered cause I am out in the country and it always takes several days to a week to get parts delivered before I dig too deep into taking things apart and had everything sitting in my non fully enclosed barn where it gets quite dusty on windy days.
   / Three point hitch slow leak down and hiccups when in use #18
Let me attach some beautiful old Yanmar illustrations on their 3pt. from 50 years ago. It will give you a better idea of how the sytem works. Every part will be different of course, but still nobody has bettered Ferguson's original 3pt and they all work basically the same.
1_Artist Cutaway view of YM240 3pt hydraulics.png2_Nomenclature of the hydraulic system.jpg3_Raising the 3pt lift arm.jpg4_Lowering the 3pt lift arm.jpg5_Control Valve 3pt in Neutral position.jpg
Wow those are probably the best illustrations I have ever seen for anything I have owned. So the stop valve pretty much hydro locks the 3pt when in any up position and like you mentioned it can only leak down from either there or past the piston. The only other way I see it loosing pressure from the illustrations is from the hydraulic pressure outlet. Maybe I should check that as well…if the stop valve is working properly that would not happen though. I appreciate you sending those illustrations over that really helps me understand the flow and how a 3pt moves the fluid around
   / Three point hitch slow leak down and hiccups when in use #20
Yes, mechanical drawing used to be a required course for mechanical designers. At one time all designers could make a creditable drawing. Of course some were better at it than others. Yanmar hired real artists. That first drawing is museum quality in my eyes. Tremendous detail and done by someone who understood how it worked.
The old US series of Yanmars were trying to emulate John Deere's excellent manuals back 50 years ago. I'd say they succeeded.
Not shown is the filter you mentioned. It is in series between the "strainer" and the "geared pump".
rScotty
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
Ryan Walk Behind Aerator (A59228)
Ryan Walk Behind...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56438)
Greenworks...
1996 Sunflower 1543-38 Folding Disk (A56438)
1996 Sunflower...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
