to buy or not to buy - b6000E
   / to buy or not to buy - b6000E #41
<font color="green"> does the PTO shaft on a b6000 turn faster than that on other tractors </font>
Mith,
It is a 3 speed PTO
With Engine speed @ 2700 rpm
1st 560 rpm
2nd 840
3rd 1350
I run the cutting deck in second.
Hope this helps.
Gary
so the converter could be used straight from the engine
neat - thanks
so what are the other gears for? /forums/images/graemlins/grin.gif
   / to buy or not to buy - b6000E #43
<font color="green"> so what are the other gears for? </font>
Not a clue!!!!
I would imagine there are some attatchment that may need those speeds? Just don't know what they might be.
Maybe nice for a post hole digger to use the slower speed, but it turns the wrong way!
Gary
yes thats why im liking the idea of one of those converters /forums/images/graemlins/grin.gif maybe a weekend project one of these days
ah well thanks for you help again
only 2-3 weeks to go!!
nother question if i may -
does the 3 point linkage only have powee up and not power down - it has to have weight on it to get it down?
thanks in advance
   / to buy or not to buy - b6000E #46
Mith,
It is "power up" only. But it takes very little weight to drop. I have an "everthing utility bracket" I have made, it weighs maybe 50 lbs, and it is enough for it to drop smoothly.
Hope this helps,
Gary
ok thanks
do you tink that with the addition of a valve somewhere in the hydraulic ystem dual acting hydraulics could be added for like some remoted for a rear blade or something
i guess it can be done for loaders and the such
thanks for you help, much appreciated
   / to buy or not to buy - b6000E #48
Mith,
I think the only way you are going to be able to accomplish this would be to add a set of rams and associated plumbing to drive the hitch down. The system in the B6000 uses a one way piston, it is lowered by releasing the hydraulic fluid.
Or maybe a big set of springs?!!!!!!!!!!!!!!!!!!!!!!!
Gary
im not necessarily interested in making the 3pt power down - just thinking about two way remotes so i can have something like a ram that powers in/out for example to turn a blade
dont worry, you answered the question anyway
if i ask too much tell me, i dont want to waste your time
thanks
   / to buy or not to buy - b6000E #50
<font color="green"> if i ask too much tell me, i dont want to waste your time </font>
Not at all...
I am happy I can be of some help!
Gary
Cushman Cart (A55853)
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
John Deere 7130 (A53314)
John Deere 7130...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
