to buy or not to buy - b6000E
   / to buy or not to buy - b6000E #41
<font color="green"> does the PTO shaft on a b6000 turn faster than that on other tractors </font>
Mith,
It is a 3 speed PTO
With Engine speed @ 2700 rpm
1st 560 rpm
2nd 840
3rd 1350
I run the cutting deck in second.
Hope this helps.
Gary
so the converter could be used straight from the engine
neat - thanks
so what are the other gears for? /forums/images/graemlins/grin.gif
   / to buy or not to buy - b6000E #43
<font color="green"> so what are the other gears for? </font>
Not a clue!!!!
I would imagine there are some attatchment that may need those speeds? Just don't know what they might be.
Maybe nice for a post hole digger to use the slower speed, but it turns the wrong way!
Gary
yes thats why im liking the idea of one of those converters /forums/images/graemlins/grin.gif maybe a weekend project one of these days
ah well thanks for you help again
only 2-3 weeks to go!!
nother question if i may -
does the 3 point linkage only have powee up and not power down - it has to have weight on it to get it down?
thanks in advance
   / to buy or not to buy - b6000E #46
Mith,
It is "power up" only. But it takes very little weight to drop. I have an "everthing utility bracket" I have made, it weighs maybe 50 lbs, and it is enough for it to drop smoothly.
Hope this helps,
Gary
ok thanks
do you tink that with the addition of a valve somewhere in the hydraulic ystem dual acting hydraulics could be added for like some remoted for a rear blade or something
i guess it can be done for loaders and the such
thanks for you help, much appreciated
   / to buy or not to buy - b6000E #48
Mith,
I think the only way you are going to be able to accomplish this would be to add a set of rams and associated plumbing to drive the hitch down. The system in the B6000 uses a one way piston, it is lowered by releasing the hydraulic fluid.
Or maybe a big set of springs?!!!!!!!!!!!!!!!!!!!!!!!
Gary
im not necessarily interested in making the 3pt power down - just thinking about two way remotes so i can have something like a ram that powers in/out for example to turn a blade
dont worry, you answered the question anyway
if i ask too much tell me, i dont want to waste your time
thanks
   / to buy or not to buy - b6000E #50
<font color="green"> if i ask too much tell me, i dont want to waste your time </font>
Not at all...
I am happy I can be of some help!
Gary
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
Sterling 9500 (A55302)
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2014 Freightliner Cascadia 125 Day Cab Truck, VIN # 3AKJGEBG5ESFM4782 (A54865)
2014 Freightliner...
2012 Toyota Prius Hatchback (A55853)
2012 Toyota Prius...
183 (A52705)
183 (A52705)
