top link question
   / top link question #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
Anyone know where I can buy a top link with a class II on one end and a class I on the other? Class II is too wide to fit on a 3 pt hay fork. I'll cut the connection apart and re weld on the implement if necessary but a hybrid top link would be much easier.
   / top link question #2
So you want a cat 2 tractor end and a cat 1 rod end, or just a narrow (1 3/4") cat 2 rod end?
I can build whatever you need. What tractor is this for?
   / top link question
More narrow rod end is fine. JD 6403
   / top link question #4
I made one up and have been using it for years. The threads are the same so I just bought a CAT II end. I like it because it's not so bulky and heavy.
Probably got it at TSC
   / top link question #6
when i got my new 3930 ford newholland it came with it just like you want.
   / top link question #8
Hello joeu235, when I had that problem I just ground down one end of a cat II top link to fit (both sides so it stayed centred ).
   / top link question #9
I did the same thing once so it fit into the narrow hitch on the tractor. It was a Cat II in pin size but too narrow for the ball to fit so a couple minutes with a grinder solved the problem.
   / top link question #10
They make them. Alot of cat 1/2 oem tractors come from the factory with just such a toplink.
My own Kubota MX toplink is like that.
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
48" Pallet Forks (A59814)
48" Pallet Forks...
Kubota B2601 Utility Tractor (A57453)
Kubota B2601...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
