Trailer shaking at 60MPH
   / Trailer shaking at 60MPH #41
Maybe I am over thinking? Antifreeze is nasty, doesn't dry or evaporate. It will coat the tire, wheel and valve stem. Anytime you check the air, I would think a spec of antifreeze would get in the gauge. You would also need to wash the tire and dry it, for a patch to stick.
Yea, you're overthinking it. I have antifreeze in all my tires, trucks and trailers, as dynamic balancers. I've had a couple of them patched; it's never been problem; it's a couple ounces for crying out loud, not a toxic waste dump. It's inside a tire, how many times do you have to deal with the inside of a tire? Let's see: a truck, Pathfinder, trailer, ZTR, tractor, RTV tires - in 7 years, maybe two trips to the tire dealer for a tire patch. BFD.
Checking air pressure: AF drops to the bottom due to gravity (which never fails); the amount getting into a pressure gauge is minuscule. I've checked my tractor and ZTR tire pressures all the time - which are 75-80% filled for ballast purposes - still no big deal.
Nasty? Use RV antifreeze, it's potable water compatible.
   / Trailer shaking at 60MPH #42
You are obviously fine with it, that's all that matters.
   / Trailer shaking at 60MPH #43
Good thing!
Hauling a tall stack of old grass clippings around calls for a smooth running trailer!
And my Wal mart push mower (self propelled, of course) :laughing:
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
3PT TRAILER MOVER (A52708)
3PT TRAILER MOVER...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
