Trailering: Anybody using Tow & Stow?
   / Trailering: Anybody using Tow & Stow? #21
The OEM Heavy Duty trailer package on our vehicles is 100% identical. You will need the electric brake controller installed as well as get a weight distributing hitch to put into your receiver hitch opening. The brake controller will be installed inside the cab and operate through a new electrical output which is installed on the rear of your vehicle, utilizing the original wiring harness. I am not sure which brake controller I have, but it is adjustable via electrical LED outputs to indicate the amount of current and therefore the amount of brake engagement, as well as the proper timed delay to avoid instant lock up when applied.
   / Trailering: Anybody using Tow & Stow? #22
Your trailer coupler will have to be a weight distributing trailer coupler if it is not already a specific weight distributing trailer coupler. There are specific attachments for the weight distributing arms on it, to which your weight distributing hitch will attach to and you adjust the pressure of these two load leveling and sway inhibiting arms. The trailer coupler is on your trailer, not your vehicle.
Look at the Draw-Tite site again or the U-haul site under "Weight Distributing Trailer Hitch and Trailer Coupler Tongue" to understand what I am describing.
   / Trailering: Anybody using Tow & Stow? #23
<font color="blue"> It also has a breakaway switch with battery, by the way. </font>
Make sure the wiring for your trailer connector has a lead that will charge the battery when hooked to your truck.
Please excuse my not stating what type of hitch you needed in the first place. If you had time to read the post I linked to. You will see why I was reluctant to come out and say you need something other than the Tow & Stow. /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
I believe J. D. Sanders is the RV dealer you're talking about. They're one of the dealers for 'Draw-Tite'. Is that the hitch brand you got?
   / Trailering: Anybody using Tow & Stow? #25
I got mine installed @ J.D Sanders, they did an excellent job. You can also get the brake controller installed there too. The entire weight distributing hitch, trailer coupler, and brake controller installed are about $800. Talk to them, they have plenty of experience with weight distributing hitches.
Yes, mine is a Draw-Tite.
   / Trailering: Anybody using Tow & Stow? #26
I am so glad that this thread evolved into what it did. The linked thread showed almost the exact same situation and turned into a hoopla. I was worried it was the same poster back under a new screen name to fire us up.
Rolando, I have pretty much the same truck as you, a half ton z71 GM pickup with the z82 HD towing package. I have a "tow rating" of 6500 and I purchased a 10,000 lb GVWR bumper pull trailer to haul my 4000 lb tractor. The total trailer weight is usually around 7000. I bought the bigger trailer for a safety margin and for future heavier pickups and loads.
I use a weight distributing hitch inserted into the GM class 3 receiver. The WD hitch system is rated as 10,000 lb trailer/1000 lb tongue combination which matches the receiver's rating exactly. I have no extra sway control like the dual cam or frcition sway control. The trailer has the bulldog coupling and I really like it though I have seen the more typical couplings used on heavy RVs so I know they make some stout ones. Be sure that every link in the chain is rated for the load. Right down to the fancy 2-5/16" ball which was 20$ for the one rated at 10,000 and only 7$ for the 6000 lb version.
I use a tekonsha voyager brake controller but next time I will step up to the tekonsha prodigy which is supposed to be quite a bit better though mine works just fine and was easy to install onto the wires that GM hid along the frame for just this purpose. 7-pin RV trailer plug. Safety chains and the emergency break away setup.
Oh and I found a newer brand of WD hitch at my local RV dealer made by Robyn industries for 260$. Very nice kit and the dealer had sold many with no issues. The other common name brand hitches were in the 450$ -500$ range.
   / Trailering: Anybody using Tow & Stow? #27
No problem, I know Rolando and he is just getting started setting up his Yukon for some heavy duty towing, he will get it right, especially with everyone's help here (although he did purchase a ToolCat instead of a B-3030 /forums/images/graemlins/blush.gif LOL )
Thanks allot for helping out! /forums/images/graemlins/wink.gif
Thanks, Joe and everyone else that that responded to this thread and put up with my ignorance,
The light bulb finally lit this morning. It's hard to communicate effectively when one of the parties (me) doesn't understand the terminology correctly. But I think I'm finally getting it!
That's the beauty of this forum. Despite my clueless-ness, I was finally able to absorb the useful information. The trailer dealer had yet to mention the weight distributing hitch, despite the fact that I ordered a 9,600 lb rated trailer. But that could be because he was assuming I knew what I was dealing with. In any case, I'm finally beginning to figure it out.
</font><font color="blue" class="small">( although he did purchase a ToolCat instead of a B-3030 )</font>
Hey!/forums/images/graemlins/mad.gif /forums/images/graemlins/wink.gif
   / Trailering: Anybody using Tow & Stow? #30
heheh, just had to rub it in! /forums/images/graemlins/cool.gif
Can you expand on what the purpose and benefit of the BullDog coupler is? I've googled and found several examples of it, but I don't understand the difference between that and the A-frame 2-5/16" coupler that comes with my trailer. Also, I'm not sure how the BullDog coupler could be installed on my trailer. I've attached some pictures of it from brochures, although the hitch doesn't show up that well.
I don't understand why the trailer wouldn't come with the type of coupler that's appropriate for a 9,600 lb-rated trailer. It looks to be a good quality trailer otherwise.
  • 764346-Aluma8200.pdf
   / Trailering: Anybody using Tow & Stow? #32
The triangular coupler with the ball head attachment appears to look fine in that photograph, however there does not appear to be the cam installation for the weight distributing rods that attach to the couple neck, which are required for the weight distributing hitch attachment to the trailer's yoke.
Go back and look at the Draw-Tite site again and see the description of the weight distributing hitch setup. In addition to the specific heavy duty forged weight distributing ball hitch which slips into your square Class IV receiver on the end of your Yukon, there are also cam attachments on both sides of the trailer yoke for the attachment of the 1,000 pound weight distributing hitch cam rods to the trailer.
The coupler is a bolt on unit, as are the cam attachments. I would imagine that your coupler is capable of handling the load, you just need the installation of the cam attachments on the trailer's yoke if you do not already have them present.
Assuming that the trailer is setup for what it is that you are doing is NOT the proper way to approach this. You should assume that your trailer is NOT setup properly and proceed from there.
Take your trailer to J.D. Sanders or Texas Trailers over there on 441 behind your Yukon and have them install a Weight Distributing Hitch for you. You do not need anything else besides the electrical brake controller unit installation. They are both fully capable of doing this with out any problems.
   / Trailering: Anybody using Tow & Stow? #33
Bulldog, first of all, is a brand name, as is Coke or Kleenex... it describes a different method of clamping the coupler to the hitch ball. The advantage of the Bulldog, as I understand it, is that it automatically adjusts for any wear of either the ball or the the coupler.
A Bulldog coupler is not required for any specific size of trailer, as far as I know. It is a preference (and recommendation) of some -- not a requirement. A 2-5/16" A-frame coupler is sufficient, and if it came on the trailer new, as you stated, it should be rated to exceed the 9,600 lb rating of your trailer. It is likely either a 10,000 lb or 12,500 lb rated coupler. It should work fine, especially for occasional use.
Attached is a picture showing a normal A-frame hitch coupler on top and a Bulldog coupler on the bottom.
   / Trailering: Anybody using Tow & Stow? #34
I just gave BullDog as an example of a high quality forged high strength trailer ball coupler, which it is.
Certainly there are other brands/models that are capable.
However, the weight distributing cams still need to be installed on the trailer yoke to attach the cams to......
This really isn't rocket science, J.D. Sanders can install the entire setup on the vehicle and trailer in a morning or afternoon and give you instructions how to use it safely and properly.
Thanks, Thom, I'll take it a step at a time. Once I have the trailer, I'll take it over to Sanders and see what they say about the coupler on the trailer.
   / Trailering: Anybody using Tow & Stow? #36
It costs around $500 for the weight distributing hitch itself, it is solid forged steel. The brake controller costs about another $100 or so.
They do an excellent job and the Draw-Tite hitch is first class.
   / Trailering: Anybody using Tow & Stow? #37
I haven't seen anyone mention the reason for needing the weight distribution type hitch. The purpose is to maintain a level truck with the necessary tongue weight when hauling heavy loads. It is recommended to have a minimum of 15 percent of you total towed weight on the tongue. An example would be if you were towing 6000 pounds you would need a minimum of 900 pounds of tongue weight. Having this tongue weight will prevent trailer sway. Having 900 pounds of tongue weight that far out behind the rear truck axle would make even a 3/4 ton truck low on the tail. Not only would everyone think your bright lights were always on, but also this condition is very damaging to braking. In an emergency stop the trailer would be pivoting the front tires of the truck off the ground as which are the most important tires for braking.
   / Trailering: Anybody using Tow & Stow? #38
I bought my 8,000 lb-rated Hidden Hitch weight distributing hitch on sale at JC Whitney a while back for $250 with free shipping. They're now a little under $300 (see link below) and there's 6,000lb, 8,000 and 10,000 ratings.
I'm not trying to sell them nor endorsing JC Whitney -- only pointing out that they all don't cost $500. I bought this one because it is still "brand name, made in USA" but not as expensive as some others -- and have been quite pleased.
Your mileage may vary...
Hidden Hitch
   / Trailering: Anybody using Tow & Stow? #39
Please double check your source for tongue weight percentages. All of the information that I have read states for a "dead weight", "Weight distributing", "Bumper Pull", or whatever else you want to call it, states for a 15% max tongue weight or 10% minimum. For Gooseneck and fifth wheels 15-25% pin weight.
Besides that... good reminder that even for 3/4 and 1 ton usually state a maximum (verify year and model for specifics) 7500# dead weight or 750# tongue weight before a WD hitch is required.
NOTE: please remember to verify each vehicle year and model as these numbers can change between year and/or Model. Even if you don't exceed tow capacity you might exceed payload capacity. /forums/images/graemlins/blush.gif
edit:
Please use actual vehicle specs., most hitches state the max for the hitch not the vehicle.
Kurt
   / Trailering: Anybody using Tow & Stow? #40
KAB I agree with the 10-15 percent values being stated but have also seen printed 10 percent minimum. In my experiences I have never had any problems towing with too much tongue weight when using a weight distribution hitch but have many times experienced sway due to not enough tongue weight. This being said, I want to make it clear that I don't exceed the tongue weight rating of the hitch or truck. A good example would be towing a smaller load like a 1500 pound loaded trailer, I don't see any disadvantage of having 300 pounds of tongue weight.
On the flip side of less that 10 percent tongue weight.......... I once owned a small 5x8 tilt trailer that I often used and abused well beyond its capabilities in my younger/dumber days. I hauled 16 foot 6x6's having 8 feet hanging off the back. Keep in mind that this trailer from the factory was perfectly balance with 0 tongue weight. Fortunately my distance from the lumber yard was only 2 miles. I had major negative tongue weight and could not exceed 15 MPH without violent sway. The bad thing about an 8 foot trailer of this design is that even if I hauled 8 foot sheets of plywood the trailer would sway if I drove over 30 MPH and empty it would sway at highway speeds.
To summarize, when I load a trailer I error to the side of more tongue weight.
Also, here is a link to the towing guide which shows vehicle tow ratings.
Towing Guide Towing Guide
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2018 CATERPILLAR...
2021 KOMATSU PC490LCI-11 EXCAVATOR (A60429)
2021 KOMATSU...
2008 KOMATSU D51PX-22 CRAWLER DOZER (A60429)
2008 KOMATSU...
43023 (A59228)
43023 (A59228)
2011 JLG E400AJP MAN LIFT (A60429)
2011 JLG E400AJP...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
