Trimming around chain link fence
   / Trimming around chain link fence #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Hi all,
I have been using a weed trimmer around my chain link fence.
Needless to say its a big pain in my butt. It chews through line
like no tomorrow.
Wondering if any of you folks have figured out a better solution?
Thanks
Dave
   / Trimming around chain link fence #2
Good call bringing this up. I have chain link around my pool and have the same experience, and in fact it was bugging me this weekend. I wish I had a good way of handling it, but I just chew through the line or have to go back a pull the grass out of the fence by hand.
   / Trimming around chain link fence #3
Round up or something like it. adjust the sprayer tip so you get a thin path. The brown stripe under the fence is really nice once you get used to it.
   / Trimming around chain link fence #4
Does the fence touch the dirt? Release the fence at bottom of post and dig out two inches and frame and pour cement. A little costly. But a couple bags of cement a week and it done.
   / Trimming around chain link fence #6
I just had this conversation with my son around the dog fence last week (wire, not chain link).
Filling up the spool at "2.5 arms length" for each cutting twine in the string trimmer, he (my son) will go use two complete spools to complete the fence line. This past Saturday doing the work myself, only using "2 arms length" for each cutting twine in the string trimmer, I only used one complete spool and had cutting twine left over after I did the fence line.
Lower RPM's when in contact with the fence, and higher RPM's just "touching" (not in actual contact) with the fence line is the trick IMO.
You will not get every piece of tall grass, but after mowing for a month with the grass growing around the fence, it looks 10 times better after use with the string trimmer IMO.
Our dog lot is 60'x40'.
   / Trimming around chain link fence #7
havnt tried this yet but sounds good.
You can put a zip tie in each line hole and leave the excess hanging out. seems like a perfect fix for chain link
Maybe it's just me, but I have no idea what your suggesting?
   / Trimming around chain link fence #9
I took it as he is saying use zip ties instead of string trimmer line. Two zip ties in a head.
But plastic is plastic.
I say, use chemicals.
   / Trimming around chain link fence #10
Commercial quality trimmer line is often better than what a consumer buys. Fence isn't actually very sharp. Not as bad as foundation corners.
   / Trimming around chain link fence #11
:thumbsup: That's what I do, too. Just barely above an idle. Works great.
   / Trimming around chain link fence #12
Here’s my solution, I have 3/4 acres in the dog run, I have 4 of my own and foster others. I run a 2 X 8 long the bottom of the fence with holes drilled for the posts. Then all it takes is to set the deck on the top of the wood, and mow. No trimming needed except in the very corner of the inside corners, and then it’s against wood not metal. E5FF2F51-A12B-4837-AF1C-52582B224FCB.jpeg41980A28-F667-42B5-8213-3E3CD52EB955.jpeg
   / Trimming around chain link fence #13
If you can, raise your chainlink a few inches and run one or two strands of barbless wire in the gap between the chainlink and ground. Otherwise, roundup is the only choice.
   / Trimming around chain link fence #14
Here’s my solution, I have 3/4 acres in the dog run, I have 4 of my own and foster others. I run a 2 X 8 long the bottom of the fence with holes drilled for the posts. Then all it takes is to set the deck on the top of the wood, and mow. No trimming needed except in the very corner of the inside corners, and then it’s against wood not metal.View attachment 657305View attachment 657304
That's a pretty slick solution. Do the boards stay flat and not warp?
I have a Stihl cordless trimmer. Only one speed BOH.
   / Trimming around chain link fence #16
I lined our dog run with a small patio block. Then I squirt the cracks now & then with roundup.
   / Trimming around chain link fence #17
The oldest section is now 14 years old, and I had 1 board that I replaced that warped. The weight of the fence seems to keep them from warping up, and to keep them in line where they butt against each other I cut a 12 to 15 inch piece, dig a little dirt out and deck screw both ends to it. Keeps them lined up real well.
   / Trimming around chain link fence #19
Hi all,
like no tomorrow.
Thanks
Dave
Ground Clear + water + sprayer = no need to trim fence line.
Saves a lot of trimming. Ground Clear will keep grass out for about the length of one season. Apply yearly.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2013 CHEVROLET SILVERADO EXT CAB TRUCK (A60430)
2013 CHEVROLET...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2005 John Deere 7420 (A60462)
2005 John Deere...
