TV Antenna ??
   / TV Antenna ??
Thanks for all the opinions and the last map link is a great sight.It shows 2 channels within a 20 mile range for me one ABC and a PBS...The others are 80 miles or more.So I guess i should be hapy with the two if I'm able to get those.
By the sounds of the opinions of experience here its similiar to what I dealt with 20 years ago.
There are allot of variables , weather,distance,trees, height, direction of the antenna,coax type and legnth, amp or not, water in connections,number of splits to the cable. etc.
I wish now I ahd jept my old antennas and could try them but they were scraped along time ago,I have a bud who has one out back ,I might just get it and get on the roof with a small yv and see what comes in.. then decide if the smaller one linke I posted from ebay would work and take the plundge and give it a shot.
Thanks.
   / TV Antenna ?? #24
Thanks.
I would do more search and research on that one, I don't like the looks of it.
Murphy, I told you . The highest gain channel 7-51 antenna is the one to purchase.
That is what you need. :thumbsup: And try it without an amplifier first.
Most digital TV is now transmitted on these channels:
Channels 7-13 VHF-High: 174 MHz to 216 MHz (Longer elements, bigger antenna.)
Channels 14-51 UHF: 470 MHz to 695 MHz (Shorter elements.)
It doesn't matter what channel the TV station calls itself, the signal will be sent on 7 to 51 RF frequency, with the exception of a very few ch 2 through ch 6 stations.
Where I live there are three VHF-High channels, ch 4.1 and 4.2 use RF ch 27, ch 5.1 and 5.2 use RF ch 7, ch 13.1 and 13.2 use ch 13.
There a few ch 2 to ch 6 stations still on VHF-Low, check the left side of the pages on Website given, to see if you need an antenna with the longest elements, to receive VHF-Low signals.
To find what channel yours is on, click this link: Digital TV Spy - TV Channels, Antenna direction - TV Stations
My antenna is upstairs in a metal building about 40 miles from the towers, and works!
It has VHF elements added to a UHF antenna.
Got it here: Antennas Direct C2-V-CJM ClearStream2 Outdoor Digital HD TV Antenna With Dipole And CJ Mount (C2-V-CJM ) from Solid Signal
   / TV Antenna ?? #25
Here is another one that has VHF and UHF elements and works inside my house, behind the TV in a corner.
It is a RCA ANT751.
   / TV Antenna ?? #26
Does anyone know why trains disrupt the signal of HDTV?
Dave
   / TV Antenna ?? #28
Thanks Xfaxman for the explanation and the link.
Dave
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2016 Hitachi XZ300LC-6 (A47477)
2016 Hitachi...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
