TYM 233 rear axle seal replacement
   / TYM 233 rear axle seal replacement #1
sarakodi
I have a TYM 233 approximately 15 years old
Both rear axle seals are leaking and I thought I would replace them myself along with the barring's. I attempted to remove one side and cant seem to pop it out.
Has anyone ever attempted this on a TYM tractor if it's in fact the same instructions?
Thanks in advance
   / TYM 233 rear axle seal replacement #2
You'll need to remove the entire axle housing #1. It might be tricky because there are a couple of close fit alignment pins, along with RTV that tends to glue things together.
Keep in mind all the brake parts. I don't know if those stay in the tractor or come with the housing.
Then, should be a matter of taking the snap ring #15 out and slide the shaft out, so you can finally get to the seal.
Thanks in advance
Thank you ptsg
Looks like this machine is going to get loaded onto trailer and taken to someone who works on them.
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
