5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 26,998
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
I love reading the Pups posts. They are so refreshing. Just like the stack gas from a coal fired generating plant.
My day job is at a Western Star/Freightliner dealer so I'm around class 8 diesels all the time and have been for years and I'll tell you all too, that when refineries went from high sulfur fuel to 500ppm or less, pump failures went up along with injector scoring. Cummins especially suffered from premature seal failure, while Caterpillar suffered from cup failure. Older PT pump equipped NT engines needed replacement gasket sets for the pump and Caterpillar redesigned their injectors. Then the Fed went crazy with the new emission standards. In 2010, the exhaust air (from the muffler) will be cleaner than the intake air, but at what cost. 2005 engines have catalytic convertors as well as compound turbocharging (cat) and EGR recirculation systems (DDEC and MB). 2006 is the first round of the 2010 benchmark and the added cost of emissions related componentry will add around 10K to the price of the truck. Trucks will have, in addition to EGR, particulate filters and exhaust afterburners (Cat). By 2010, DDEC will cease to exist. Detroit Diesel can't meet the 2010 emission standards. HEUI engines like the Navastar Diesel (Powerstroke) and the HEUI Caterpillar engines rely on sulfur to lubricate the close tolerance surfaces in the pump and unit injectors and all the other engine manufacturers also rely on sulfur as a lubricant. Consequently, Caterpillar Engine Company has developed an additive for their engines and others that replaces the lubricity lost from the removal of sulfur. It's available from any Cat Engine dealer. I use it religiously in my Powerstroke and my Kubota, which, has a close tolerance rack style pump. I'd suggest using either the Cat additive, Powerservice or Lucas Fuel Treatment.
Someone told me that Sky Pup was a Sanatation Engineer. I'll buy that. He seems to sling great amounts of bull poop around.
