Upgrading from a JD332 to a JD2210?
   / Upgrading from a JD332 to a JD2210?
Following up on this 2210 transition. I'm loving the 2210 in general.
My only gripe about the machine is that the 3 pt hitch hydraulics does not appear to be set up to follow the position of the control lever. On my 4600, the height of any 3Pt implement is easily set by the control lever. Want a blade just a little higher, then raise the lever just a little. A little down? Just drop the lever just a bit. So the implement accurately follows the position of the lever. Not with the 2210. The control lever on the 2210 can raise and lower the 3 point, but it's more like a spool valve than a proportional control. Positioning the implement involves a little bit of "up" or a little bit of "down", but the lever position does not directly control the height of the attachment in a proportional manner like it does on the larger 4600. Am I missing something?
   / Upgrading from a JD332 to a JD2210? #32
Might suggest you start a thread that introduces the problem in the subject line, and not under the lawn tractor forum.
To me, sounds like a linkage adjustment, if not debris in the control valve.
I'd be surprised if the 2210 is designed the way you say yours works.
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
1998 Mac 39' Frameless Dump Trailer (A59814)
1998 Mac 39'...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
