V10, no power.
   / V10, no power.
Changing out the plugs has been on my "to do" list for awhile now. I have had coil packs go bad but the engine runs smooth and while setting, the throttle reponse is normal.
My oxygen is out for my torch so I decided to cut the pipe behind the cat, gut it out then band clamp it. I will get back on the results later on today.
   / V10, no power. #33
I had an issue that was similar in a class C motorhome with a V10...It lacked power and was surging under load. Turned out to be a bad coil pack.
Ditto, same here - problem worsened after a couple of days to a severe shudder, replaced two coil packs.
   / V10, no power. #34
So what are you saying Timswi, never pull codes? Its a computer, it spits out info, its up to the person reading it to decide what to do. I've gone to Autozone, had the codes read 2 or 3 times for free, bought the part the scanner said was bad, and fixed it. I will say when having a problem like the OP has, ALWAYS run a scanner on it first. What if he farts around with and fixes a bunch of stuff that wasn't bad, finally runs a scan on it, and some $10 part is bad.
   / V10, no power. #35
I thought of another car I had looked at to purchase, when I test drove the car it ran fine and idle and even up to around 35mph, but when trying to reach hwy speed of 55-60 it was a dog, I took it by our local autozone to let them pull a scan code, it wound up being th o2 sensor, I purchased the car at a cheap price because of the way it ran, fixed it for 45.00 and drove it for 3 years, doubled my $$ when I sold it,:cool:
I just saying there can be so many things to cause this, It's probably best to run a scan on it before doing allot.;)
   / V10, no power. #36
timswi said:
As far as the cat, I would guess that you'd have to have a poor running motor to wipe one out in the first place. I ran 2 '90's GM 5.7 4x4's for over 200k miles and never had a problem with a cat...Prior to those, I'd buy GM cars with 100k or so and drive them to 140k and never replaced one on those either...The only cat failure I had to figure out belonged to someone else and that thing was running terrible for a long time due to complete neglect. Not sure that the OP falls into that category.
Not always, when a cat con chokes up in our fleet vehicles it is usually our slow and easy drivers. All of the vehicles are maintained the same. Had one clog at 50k.
   / V10, no power.
It was already dark until I got time to work on the truck. I polished up the pipe behind the cat with my grinder and a wire wheel then cut it off leaving just enough room for the band clamp. I had mentioned possibly using my torch to break the pipe about two feet back where it goes into the muffler. That certainly would not have worked.
I found at least three baseball sized pieces of ceramic rolling around in there. Being fairly round, I figure that the last one would roll to the outlet and chock it off. I had not thought about how hard it would be to break this stuff up though I have worked with ceramics. I have gathered an assortment of long tools including a three foot point for my jack hammer. The ceramic "balls" don't want to cooperate at all but I am making headway. Everything is iced up so I would not have wanted to take the truck out anyway.
It sure would be easier just to cut the cat out and put a pipe in but when I get done at least it will look somewhat stock other than the new band clamp.
   / V10, no power. #38
I didn't say don't pull the codes. The mechanic up the road said that the codes thrown by the ECM on Fords can be deceiving (he maintains a fleet of Ford trucks for a large HVAC company). He told me that the OBDII codes on a $200 scanner can send you down the wrong path. The Snap-On's and whatever the dealers use give a more complete picture...I used my scanner to diagnose my Ford and it only showed lean, no misfires when there definitely was one.
   / V10, no power.
It was the cat. Using a shop vac and a piece of wire I was able to pull the heavier pieces to the rear where I could get on them with a pry bar with an angled tip. A little pressure and they would break into small enough pieces to get through the pipe. I also started the engine a few times to blow the debris out that the shop vac was not able to remove.
I also went ahead and replaced the fuel and air filters before I took it out for a spin. Usually I would have tested it with the cat gutted first then changed the filters but it was getting late. I did not push the cold engine to hard but the truck did take a couple hills just fine.
So, the plan is now to get the truck on a computer in the next few weeks and at the least put in new plugs.
Thanks for all of the suggestions.
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Booster Cables (A59230)
Booster Cables...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
