Well seems to randomly shut off?????
   / Well seems to randomly shut off?????
Well guys, I might have found the problem, I was able to check out the system Sunday afternoon (sorry for not getting back sooner). I first took off the cover to the pressure control switch. The contacts had some build up, I tried to find a replacement one, but all of the ones at home depot and lowes were very chessy looking. Sooo, I cleaned up the contacts with some sandpaper. I am going to get a good one in the near future since they are relatively cheap. The one that is on there is a square d, and has alot of adjustments as far as presure triggers and such, the ones at the mega stores are fixed pressure no names. Does cleaning the contacts last any length of time?? I was able to check out the wiring on the reset switch thing. It is inline between the pump and the presure switch. I think in might be some sort of breaker device since it looks like a big single gain switch. I was going to take a pic, but the misses has the camera. hopefully this will keep me going for a little while, there is nothing worse then running out of water.
Again, thank you all!!!!!, Dave
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bolt Bin (A57454)
Bolt Bin (A57454)
F-150 Running Boards (A57454)
F-150 Running...
John Deere 204L (A56436)
John Deere 204L...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
