What is needed hydraulically for a grapple?
   / What is needed hydraulically for a grapple? #11
I can take pictures if you would like. Let me know what you decide.
   / What is needed hydraulically for a grapple? #12
Yep... Adding the first rear remote is going to co$t more on a Kubota...
If do not see a need for rear hydraulics the third valve from Tom at everything attachments is going to be quick and easy.. Or you can shop around and get an electric solenoid system using one of your loader functions for around $300... KennyV
   / What is needed hydraulically for a grapple? #13
Kioti is not the same as kubota anymore. Different parts. I checked everywhere.
   / What is needed hydraulically for a grapple? #14
With the setup I came up with I could easily "T" into my lines out of my extra valve and run hoses to the rear also for rear remotes. Would have one lever to run two sets of outputs. One front and one rear. Just depends on which set you have an attachment hooked up to.
   / What is needed hydraulically for a grapple? #15
I don't think anyone meant to imply they were interchangable. However, they are essentially the same types of parts and it is rediculous that Kubota charges double.
   / What is needed hydraulically for a grapple? #16
Hope this helps
   / What is needed hydraulically for a grapple? #17
No doubt a rip off. Check out my setup. $250 v the $750 from kubota. Made the bracket and piped it in. Price includes everything down to the 177" hydraulic lines to the front of the loader.
   / What is needed hydraulically for a grapple? #18
No doubt a rip off. Check out my setup. $250 v the $750 from kubota. Made the bracket and piped it in. Price includes everything down to the 117" hydraulic lines to the front of the loader.
   / What is needed hydraulically for a grapple? #20
Thanks. Saved a ton. Plus it all has QuickConnects in case I decide to detach my loader. Works great and doesn't look too bad.
2016 Ford Taurus Sedan (A56859)
2016 Ford Taurus...
2016 Audi A3 AWD Sedan (A56859)
2016 Audi A3 AWD...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
TRAFFIC ENFORCEMENT UNIT SPEED TRAILER (A58216)
TRAFFIC...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
2002 Lexus SC430 (A57148)
2002 Lexus SC430...
