What is the proper way to install a 3 pt rear blade
   / What is the proper way to install a 3 pt rear blade #11
Several posters suggested shortening the top link. I don't understand how you could do that. Whenever I plow snow I turn the blade fairly sharply to one side so the snow is discharged to the side as I plow. If I were to shorten the top link the leading end of the blade would dig sharply into the road while the trailing end would be high in the air. I always have to keep the frame nearly level to keep the blade parallel with the road along its length.
Terry
I've found the lighter tractors (I have an L3650) have plenty of horsepower to pull the snow, but when you angle the blade sharply the snow can easily push the front end around. So I angle the blade only to the first notch - it "pulls" more snow along (which the tractor has the horsepower for) but due to the slight angle, it doesn't push the tractor around as much.
This is contrary to what you try first by giving the blade a bunch of angle to discharge the snow as fast as possible.
   / What is the proper way to install a 3 pt rear blade #12
Terry
You need to adjust the sidelink to level it.
   / What is the proper way to install a 3 pt rear blade #13
There isn't enough range in the sidelink adjustment on my JD 870 to overcome any noticeable amount slant to the frame. In fact, I mostly ignore the sidelink adjustment when I do want to cant the blade at an angle to clear the ditch, and adjust with the top link instead. Do other tractors have more range in the sidelink adjustment?
Terry
   / What is the proper way to install a 3 pt rear blade #14
Yes, and you can end up in the ditch, as I know from experience. :-/
I find a bit more speed in plowing works better than a sharper angle. Still, even at the first notch on my blade, there's to much angle added to the blade if I don't keep the frame nearly level, even after adjusting the sidelink as far as it goes.
Terry
   / What is the proper way to install a 3 pt rear blade #15
Several posters suggested shortening the top link. I don't understand how you could do that. Whenever I plow snow I turn the blade fairly sharply to one side so the snow is discharged to the side as I plow. If I were to shorten the top link the leading end of the blade would dig sharply into the road while the trailing end would be high in the air. I always have to keep the frame nearly level to keep the blade parallel with the road along its length.Terry
I agree. That was the point I was trying to make in that long discourse. But if someone insists on shortening the top link, which is OK with me, to make the blade less aggressive it may float up on you.
I keep the frame and blade level like you do so that I can put the blade at any angle w/o readjustments. If it digs in I just raise it a little.
   / What is the proper way to install a 3 pt rear blade #16
Terry
You should be able to get about 10 degrees of tilt to either side with your side link adjustment. ;)
   / What is the proper way to install a 3 pt rear blade #17
If you replace both vertical 3 point links with chains, the rear blade will follow
the contours of your driveway and not dig in. I started doing this about 6 years
ago when I found that the rear blade would gouge my gravel driveway.
Replacing the 3 point links with chain lengths that allow the blade to "float",
and hey presto, no more driveway damage. The blade is heavy enough to cut
down through the snow to the bottom. When you raise the 3 point, the chains
tighten up and raise the blade. Couldn't be simpler. The blade follows the driveway
contour and not the movement of the tractor (except, of course, the pulling
motion).
   / What is the proper way to install a 3 pt rear blade #18
Really! I don't think I can get half that. I'll look again next time I get my rig out.
Terry
   / What is the proper way to install a 3 pt rear blade #19
Terry
Alot of tractors have additional holes in the lift arms so you can get more tilt or in thr sidelink itself.
Here is the plow with hydraulics all the way down
Pic with hydraulics about 4 " up plow is just touching ground.
I can see if I lengthen the top link it will sit more level
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
*Selling at Royal Auction Tampa, FL Location* 9, gooseneck hitch, (A59230)
*Selling at Royal...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56438)
2019 BOBCAT T630...
