What size fire Extinguisher???
   / What size fire Extinguisher??? #31
Frank. . . funny you said you were amazed how fast a 20# extinguisher runs out. Most people only see extinguishers used on TV or the movies and think they keep spraying as long as you squeeze the handle . . . Go try one of those little 3# jobs, they literally give you a shot that only lasts about 2 SECONDS.
I guess I look at fire extinguishers the same way I look at guns . . . you don't need them very often, but when you NEED one, you NEED IT NOW.
   / What size fire Extinguisher??? #32
[blue]junkman i beleive that is a grandfather type thing. if it is an exsisting system it is ok, but new systems must use something else. halon along with refigerants such as R12 are now outlawed. [/blue]
Frank is right. Most computer rooms use Inergen, which is a proprietary blend of nitrogen, CO2 and other gases. It's safe for the environment and non-toxic, although it could be fatal to be in a room when an Inergen system activates, because it will displace the oxygen in the room.
   / What size fire Extinguisher??? #33
If you want the ability to reliably fight and extinguish a fire I would recommend going with good quality extinguishers from a company like Ansul. Don’t buy the plastic handle/valve types available in the discount stores. I am sure the commercial quality extinguishers cost considerably more than the plastic throwaways, but I have heard on the cheap variety, that after aging for a few years, that the valve may stick and the handle will then break when squeezed.
I have successfully extinguished several large diesel fires using the Ansul Red Line 20 loaded with Purple-K. These are designed to be refilled and recharged by the user. If you keep the supplies on hand you can refill the same extinguisher in 3-4 minutes and immediately reuse it if necessary. The powder is poured in through the top hatch and a new CO2 cartridge screwed on and you are ready to go again. The CO2 cartridges are refillable at the factory.
Of course Ansul makes many sizes and types of extinguisher if this isn’t what you are looking for. We used this brand exclusively during all my years in the power plant and we regularly trained fighting fuel oil fires so I know they work.
They should be available through specialized fire & safety type stores.
Ansul Red Line
   / What size fire Extinguisher??? #34
Good point. Call the FD. One, yes the fire extinguisher may run out. Two, it is better to have them show up and not need them than to risk a fire getting out of control. Three, in any fire you will have a lot of smoke. The FD will set up an exhaust fan and ventilate the building very quickly to advert smoke damage to the house/contents.
   / What size fire Extinguisher??? #35
</font><font color="blue" class="small">( If you want the ability to reliably fight and extinguish a fire I would recommend going with good quality extinguishers from a company like Ansul. )</font>
all mine are from ansul! but , any extingusher is better than none. i wonder why a lot of people don't think of fire extingushers as an integral part of their home? like smoke dectors, or carbon monxide dectors?
   / What size fire Extinguisher??? #36
I picked up a couple 10# ABC extingishers today. They have a different kind of foam in them. It's some other kind of sulfate, not ammonium. They are much higher rated... 8a70b vs about 4a60b for the regular 10# type.
Supposedly the cleanup is easier, not sure if they damage electronics. They are not rechargable and the temp range is pretty bad though (only down to +14) so they'd be good for indoor only around here.
   / What size fire Extinguisher??? #37
As a firefighter and an insurance professional that has provided many hours of fire extinguishers training and who advises clients on a daily bases about fire protection in commercial applications, my comment are as follows:
First off call the fire department, and then fight the fire, if that is what you choose to do. By the time you determine your efforts are not working, it maybe too late. As a firefighter I would rather be called to a fire that is out or nearly out then pulling up and being told a person is trapped because they stayed too long to fight a fire. I investigated a fire a while back where the security staff used 40 fire extinguishers on a fire and THEN decided to call the FD, WRONG!!.
The best fire extinguisher is a garden hose, unlimited supply of agent, can handle wood, paper, etc. The NYC FD has a firefighter assigned to a 2.5 gallon water fire extinguisher on each ladder company. They call him/her “The Can Man”, they put a lot of fire out using this simple fire extinguisher. They have quick knock down of the fire often before an engine company gets on the scene. For grease, combustible metals and electric DO NOT USE WATER.
For a garage of your size I would recommend at least 4 ABC fire extinguishers, minimum 2-A:10-B:C or higher. Why four? National Fire Protection Association, NFPA would call for a minimum of 2 fire extinguishers for your size building. Remember NFPA is the MINIUM. The fire extinguisher I recommended would last about 10-15 seconds, not much time to do a lot of firefighting. REMEMBER you have called the FD and they are on the way. If the fire is not getting smaller with the first fire extinguisher, get out and close doors as you leave. I recommend 4 only so they are close by and not behind something or out of sight. Also make sure you get a new fire extinguishers every few years especially if you buy the cheap ones at the big box stores. Also look at the gauge monthly to make sure it is in the green area. If you have not had fire extinguisher training, read the label on how they work BEFORE the fire. Now that may sound like common sense, but I investigated a fire where the person said the fire extinguisher did not work. I asked the person to show me the extinguisher he used. The pin was still in the handle, the plastic handle was broken from him trying to squeeze the handle. Guess he will not forget to pull the pin the next time. Application of the agent is very important to extinguish the fire. Aim at the base of the fire, sweeping motion left to right, if the fire gets smaller move in on the fire if not get out. REMEMBER always have the exit at your back and not in front of the fire.
Regarding Halon systems currently installed in computer room or any other application and located in the United States, the following applies:
You are under no legal obligation to remove systems from service.
There is no federal legal requirement to remove systems from service by any specific date.
You may legally recharge your system in the event of a discharge
Recycled agent is still commonly available for fire system recharge.
No new agent 1301 is being manufactured.
The most common replacement gas now being used as a replacement for Halon is a gas known as FM 200. See this web site for the info on the gas. link
   / What size fire Extinguisher??? #38
Chico922, I have seen many a thing burn and know that you can stop the fire if you have the right gear. So outside my tool shed is not one but 3 fire extinguishers. 2 are water type I think 2 gallon and one is a 10-pound ABC chemical type. These are all in addition to one ones in the house, cars and trucks. It is always nice to be able to grab the water one and take it up the hill if you know you are going to be brush cutting or use a cutoff saw. I have started many small fires with the cutoff saw so having a fire extinguisher is a must. I have attached 3 photos of where I place them on the shed to give folks a better look at commercial quality fire extinguishers.
George
   / What size fire Extinguisher??? #39
Closeup of Fire extinguishers
   / What size fire Extinguisher??? #40
Second water type on side of tool shed.
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
UNUSED GRASSROOTS IMPLEMENT 6' BOX BLADE (A57192)
UNUSED GRASSROOTS...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
72'' power rake (A53421)
72'' power rake...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
