When to use 4WD
   / When to use 4WD #11
</font><font color="blue" class="small">( I have also read (I thought) not to use 4wd when doing FEL work - loading & dumping. )</font>
I leave mine in 4wd all the time except for mowing or just traveling on the lawn, especially when doing FEL work. To me its a safety thing - the heavier the load in the bucket, the less weight and therefore braking on the rear wheels regardless of how much ballast. With it in 4wd, you get braking to the front wheels as well. I know of a guy who was doing FEL work for my BIL dumping fill over a steep embankment. He at some point had grabbed the wrong lever and put it in 2wd, pulled up to the embankment to dump a heavy load and hit his brakes only to find out there wasn't enough braking power to the rears and went for the ride of his life. It happens quick.
Of course, anytime on dry pavement, I try to avoid 4wd.
Brad
   / When to use 4WD #12
As everyone has said, there should be no problem being in 4x4 any time except when on pavement. As long as the front tires can slip when turning you will be OK. Don't know about your tractor, but on mine when I am in 2wd I actually get only one wheel drive unless I engage the rear diff lock. And if I am in 4wd, I only get 3 wheel drive unless I engage the diff lock.
Having said that, I use 2wd drive probably 90% of the time since most of my work is pasture mowing and I don't need it. I use 4wd when mowing the steep ditches along the road, as much for the extra braking as the traction. And I use 4wd if I need it for FEL or box blade work or any other time I may lose traction.
   / When to use 4WD #13
Mine's in 4wd all the time except when runninng for a distance on paved ground. Even on paved ground in the snow/ice, it's in 4wd.
4wd helps in turning, particularly if you have the FEL on all the time. Without 4wd engaged, the front wheels will skid more. It also gives you 4 wheel brakes going up and down hills. So, 4wd drive is safer. You have it; use it. Wish they'd put in a slip differential and make them AWD to stay on even on paved roads.
Ralph
   / When to use 4WD #14
My tractor is in 4 wd 99% of the time....I operate on very rough terrain and do lots of hard pulling. My JD 4400 has the 4wd engage lever in a location that you can accidentally bump it out of 4wd with your foot and not knowing you have done so which can really make for an exciting moment when going down a steep hill and the tractor starts to slide because it is not in 4wd and you thought it was. I wish my JD 4400 had a 4wd engaged light on the dash that would illuminate when the tractor is in 4wd.I used my 4wd so much that the splines wore out on the collar/drive shaft and I just welded it up direct.
   / When to use 4WD #15
I use the 4WD if I need it and use 2WD the rest of the time. If I start spinning the rears it's time for 4WD. It sure does help out braking especially down a steep grade with a heavy trailer.
John
   / When to use 4WD #16
I find it essential to use 4wd on my steep slopes ...otherwise, no engine braking on front wheels ...with the FEL or Grapple on the front, it is easy to unload the rear tires and "off you go" ...no brakes and no braking ...rear counterweight is one answer, but if it's your tph rear implement and you lower it, then it puts no weight on the rear ..."and off you go"
   / When to use 4WD #17
4WD all the time cept on concrete or asphalt.
   / When to use 4WD #18
</font><font color="blue" class="small">( I know not to use the 4wd on pavement or hardpacked surfaces.)</font>
Also, don't put it in 4x4 when driving over your lawn if you care about cosmetics - 4x4 chews up grass more, especially when turning.
Jay
   / When to use 4WD #19
When turning in 4wd, one tire has to slip. The outside tire has to travel a greater distance than the inside tire. Unless it has a limited slip diff, there is no other option but for one or both to slip. If it is lawn, that likely means tearing up some grass. In any event, that slipping is putting some pressure on the gears and other drive components. Maybe not enough to hurt them on grass or dirt, but that is why I don't put mine in 4wd unless I need it.
   / When to use 4WD #20
It's visible if you drive a tight circle in fresh dirt in 4wd. You make 4 concentric circles: each tire makes its own. 4 circles = 4 circumferences = 4 distances the tires travel = 4 different speeds (different distance in the same amount of time). From side to side, the differentials let opposite wheels move at different speeds, limited-slip or not. Front and back axles, though, are geared together in 4wd, so they must move at the geared speed. The manufacturer optimizes the gear ratios for straight-ahead. When you ask front and rear to go different speeds something has to give, and that is tire slip. I'd say better dent the lawn than the diffy.
Some 4wd or AWD cars use a center differential, do any tractors? I'm not in favor in a tractor, as tire wear is less important than simplicity of design IMO, and gears are generally strong enough unless traction is perfect.
Jim
2008 Genie S-65 65ft Telescoping Boom Lift (A55787)
2008 Genie S-65...
2015 FORD E350 16FT BOX TRUCK (A56129)
2015 FORD E350...
2020 LOAD KING JBTR-56 (A55745)
2020 LOAD KING...
2023 John Deere 1025R (A53314)
2023 John Deere...
Erskine Skidloader Truss Boom (LIKE NEW) (A50775)
Erskine Skidloader...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
