Which engine would you choose?
/ Which engine would you choose? #1
Robert_in_NY
Super Member
Silver Creek, NY
Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I am looking for a 100 horse tractor to replace my 7710-II eventually and was talking to the MF dealer today and he was showing me the 5400 series. One thing I noticed and was curious about is the engine choices.
On the MF 5465 you have the Perkins 1106 (402 CID, 6 cylinder) putting out 100 pto hp. On the 5470 you have the Sisu 44CTA (269 CID, 4 cylinder) putting out 105 pto hp. Both are rated at 2200 RPM to reach their hp numbers.
I know Sisu has a good reputation as does Perkins but to me a 6 cylinder would be better then a 4 cylinder. I like the added length wheelbase the 6 cylinder provides also.
So does anyone have any thoughts? Does a 4 cylinder putting out 105 horses with less displacment seem like a better option then a 6 cylinder putting out 100 horses with more displacement?
Also, please note I am not buying one anytime soon. I just noticed these engine options today and it made me wonder.
/ Which engine would you choose? #2
With todays fuel cost, which is the most fuel efficient?
/ Which engine would you choose? #3
Sisu has a great reputation and I have had dealers tell me they are the best they have ever dealt with but for me who deals with lots of Perkins 4 and 6 cylinders I have to say that I love Perkins.
We sell the Perkins engines in our ASV machines as well as our McCormick tractors and they are great.
From all accounts I think they are both great but I bet Perkins has more support no matter where you go. The fuel efficiency thing Toad brought up is certainly something to weigh.
Maka
I know both motors have good reputations but wouldn't the 6 cylinder be smoother running then a 4 and wouldn't the 6 cylinder handle loads better then a 4 cylinder? I just keep remembering to other farmers always say you can't beat displacement and the 6 cylinder Perkins beats the 4 cylinder Sisu easily in displacement.
As for fuel usage, well, the stats don't list that but I am not sure which is better. I would almost think the 6 cylinder would be easier on fuel as it doesn't have to work as hard to get 100 hp as the 4 cylinder does to get to 105hp. Those 4 cylinders are going to have to really work and I know my 4 cylinder 7710-II sucked fuel when at full throttle.
/ Which engine would you choose? #5
If I were in your shoes one item I'd check is the difference in harmonic balancers in these two engines.
I'm no expert, but 4-cyl engines use counter-rotating shafts for dynamic balancing.
At one time I was interested in the old JD 3020, a 70-hp 4-cyl diesel. I was told that the balancers in that engine are large,heavy and need to be removed to do servicing on the bottom of the engine (I think replacing that oil pump was under discussion at that time).
/ Which engine would you choose? #6
There is no replacement for displacement. The smaller engine will have to work harder to obtain the same power #'s as a larger displacement engine. The larger displacement engine will also have a broader torque range than the smaller. They are supplying you hp #'s. Horsepower doesn't mean much, believe it or not. I would ask for torque #'s. Both at 2200 rpm and max torque at what rpm? If you took 2 tractors, same model but put the different engine in each, and hook a chain between them. The one with the larger engine would almost always pull the smaller one in circles.
As far as fuel efficiency goes, an engine runs the most efficient at it's torque peak, not horsepower peak. That's another reason I ask for torque peak at what rpm.
If I ever get to the point where I am strongly considering these two models I will have both dropped off and hooked to the plow to see how they handle. The plow is going to be the hardest task any of my tractors will see.
/ Which engine would you choose? #8
Conventional wisdom says the 6-banger would be the wise choice based on the big engine works less to produce power theory. The sterling reputation of the Perkins diesel says the 6-banger is the wise choice. Perkins direct affiliation with CATERPILLAR can't be ignored. 6 cylinder engines normally operate smoother than a 4 cylinder.
BUT....
SISU is quickly gaining a stellar reputation. Conventional wisdom of yesteryear has taken a big hit with new technology in diesel engines. Theory is just that. Theory. We can speculate 'till the cows come home. It would take real world, side-by-side comparison to fully evaluate which is REALLY the best choice. Robert, you need to buy ONE OF EACH, then report back in a year. ;)
I seem to recall hearing somewhere that the SISU engines are sort of a Perkins knock off. Anyone know about that?
I did get a set of 4 CD's on the new Massey Ferguson models at the National Farm Machinery Show in Feb. So far, they've never made it out of their jackets. Maybe time to do a little research.
/ Which engine would you choose? #9
SUMMARY OF OECD TESTS 2110 & 2111鋒EBRASKA SUMMARY 558
MASSEY FERGUSON 5465 DIESEL
16 SPEED
POWER TAKE-OFF PERFORMANCE
Power Crank
HP shaft
(kW) speed Gal/hr lb/hp.hr Hp.hr/gal Mean Atmospheric
rpm (l/h) (kg/kW.h) (kW.h/l) Conditions
MAXIMUM POWER AND FUEL CONSUMPTION
Rated Engine Speed?PTO speed?100 rpm)
97.8 2199 6.26 0.454 15.63
(72.9) (23.70) (0.276) (3.08)
Standard Power Take-off Speed(1000 rpm)
106.1 2000 6.30 0.421 16.85
(79.1) (23.83) (0.256) (3.32)
Maximum Power (2 hours)
109.4 1848 6.13 0.397 17.86
(81.6) (23.20) (0.242) (3.52)
VARYING POWER AND FUEL CONSUMPTION
97.8 2199 6.26 0.454 15.63 Air temperature
84.5 2216 5.58 0.469 15.13 68ーF (20ーC)
(63.0) (21.14) (0.285) (2.98)
63.2 2238 4.81 0.540 13.13 Relative humidity
(47.1) (18.21) (0.329) (2.59)
42.5 2259 3.97 0.662 10.72 54%
(31.7) (15.01) (0.402) (2.11)
21.0 2276 3.00 1.011 7.02 Barometer
(15.7) (11.34) (0.615) (1.38)
-- 2293 2.20 -- -- 29.3" Hg (99.2 kPa)
-- (8.32) -- --
Maximum torque - 342.2 lb.-ft. (464.0 Nm) at 1398 rpm
Maximum torque rise - 46.5%
Torque rise at 1790 engine rpm - 36%
DRAWBAR PERFORMANCE
(Unballasted - Front Drive Engaged)
FUEL CONSUMPTION CHARACTERISTICS
Power Drawbar Speed Crank- Slip Fuel Consumption Temp.ーF (ーC) Barom.
Hp pull mph shaft % lb/hp.hr Hp.hr/gal cool- Air inch
(kW) lbs (km/h) speed (kg/kW.h) (kW.h/l) ing dry Hg
(kN) rpm med bulb (kPa)
Maximum Power?th(4TA) Gear
82.6 6775 4.57 2160 6.0 0.566 12.54 183 36 29.9
(61.6) (30.1) (7.36) (0.344) (2.47) (84) (2) (101.1)
75% of Pull at Maximum Power?th(4TA) Gear
64.1 5060 4.75 2195 3.0 0.616 11.51 181 36 29.9
(47.8) (22.5) (7.65) (0.375) (2.27) (83) (2) (101.1)
50% of Pull at Maximum Power?th(4TA Gear
43.9 3370 4.88 2220 2.0 0.743 9.54 181 37 29.9
(32.7) (15.0) (7.85) (0.452) (1.88) (83) (3) (101.1)
75% of Pull at Reduced Engine Speed?th(4TB) Gear
64.6 5035 4.81 1764 4.0 0.531 13.35 178 37 29.9
(48.2) (22.4) (7.74) (0.323) (2.63) (81) (3) (101.1)
50% of Pull at Reduced Engine Speed?th(4TB) Gear
44.3 3395 4.89 1774 3.0 0.583 12.17 178 37 29.9
(33.0) (15.1) (7.87) (0.355) (2.40) (81) (3) (101.1)
/ Which engine would you choose? #10
SUMMARY OF OECD TESTS 2358 & 2359鋒EBRASKA SUMMARY 559
MASSEY FERGUSON 5470 DYNA 4 DIESEL
16 SPEED
Power Crank
HP shaft
108.0 2200 6.25 0.413 17.26
(80.5) (23.66) (0.251) (3.40)
110.5 2000 6.01 0.387 18.38
(82.4) (22.75) (0.236) (3.62)
Maximum Power (1 hour)
110.6 1980 5.98 0.385 18.48
(82.5) (22.65) (0.234) (3.64)
108.0 2200 6.25 0.413 17.26 Air temperature
92.9 2240 5.57 0.426 16.70 66ーF (19ーC)
(69.3) (21.08) (0.259) (3.29)
71.6 2284 4.69 0.466 15.27 Relative humidity
(53.4) (17.77) (0.284) (3.01)
47.9 2304 3.49 0.519 13.71 53%
(35.7) (13.23) (0.316) (2.70)
24.5 2356 2.55 0.739 9.63 Barometer
(18.3) (9.67) (0.450) (1.90)
-- 2399 1.74 -- -- 30.1" Hg (101.8 kPa)
-- (6.57) -- --
Maximum Torque - 346.4 lb.-ft. (469.7 Nm) at 1150 rpm
Maximum Torque Rise - 34.4%
Torque rise at 1750 engine rpm - 26%
DRAWBAR PERFORMANCE
Maximum Power?th(3A) Gear
88.5 5775 5.75 2200 5.7 0.510 13.91 183 57 29.8
(66.0) (25.7) (9.25) (0.310) (2.74) (84) (14) (100.8)
75% of Pull at Maximum Power?th(3A) Gear
69.6 4315 6.05 2280 4.3 0.552 12.84 183 57 29.8
(51.9) (19.2) (9.73) (0.336) (2.53) (84) (14) (100.8)
50% of Pull at Maximum Power?th(3A) Gear
47.1 2865 6.16 2290 3.0 0.635 11.17 183 57 29.8
(35.1) (12.8) (9.91) (0.386) (2.20) (84) (14) (100.8)
75% of Pull at Reduced Engine Speed?0th(3B) Gear
69.1 4295 6.03 1858 4.7 0.512 13.85 181 57 29.8
(51.5) (19.1) (9.71) (0.312) (2.73) (83) (14) (100.8)
50% of Pull at Reduced Engine Speed?0th(3B) Gear
47.5 2880 6.18 1881 3.6 0.624 11.37 181 57 29.8
(35.4) (12.8) (9.94) (0.379) (2.24) (83) (14) (100.8)
Thanks Chh, from what I can make out there doesn't seem to be much difference in numbers at least I can't see anything major stand out but copy and paste really jumbled those charts up.
Can you post the link to where you found them?
BUT....
I wish I could buy one of each. But if I did that one would be 2wd and the other FWA. The 2wd would be great for haying and other jobs that I don't need FWA for. But then again that would throw off the trials:D
/ Which engine would you choose? #13
Well I don't know if you can make that out, but they are both on the Nebraska test site. It looks like the 5470 has an edge on fuel consumption over the 5465. I looked at the 5455 and 5460. The head shop mechanic at the dealership I usually use claims the 5400 series overall has a very low rate of warranty claims and that they Dyna 4 trans is pretty much bulletproof.
I went with the 596 because there is 10 grand difference between the 596 and the 5455. But the 5400 series is a much nicer setup than the 500 series.
Link to the Agco listings.
TTL test reports/Case
/ Which engine would you choose? #14
Looking farther into the charts fuel consumption for the 5470 is less than the 5465 in pto power charts and higher in the drawbar rating charts.
Thanks Chh, I have the literature on the 500 series also and will look at it also as I don't really "need" all the fancy gadgets in the cab.
/ Which engine would you choose? #16
Went to a dealer's open house yesterday. He had his personal tractor back on the lot for sale, a MF 5465 with 1700+ hours on it and a new 5460. I will have to say that they both beat out the 596 in the "creature comforts" area, but I really don't think I could justify one for myself. He was more than willing to sell me either one though;) .
As a side note there was a Montana rep there that was telling me that they would have a 87?? hp model out in Sept. The 70ish hp one that they had on the lot appeared to be quite a bit better made than I was actually thought it would be. He indicated that Montana was trying to get tractors introduced that would be big enough to run round balers ect.
/ Which engine would you choose? #17
They're both excellent engines. Sisu is hand built in Finland and obvioulsy Perkins is from the UK. I havent had much to do with the Sisu in recent years, but the 1106 I have. You will find the 1106 around the 115 -120 hp will be a little lower in torque. The 130-135 hp engine is an excellent performer though. I think from all reports a little more fuel efficient. After all it is only a software difference that seperates the two engines. Reliability of the 1106 has been reasonably sound. But have run into the odd issues with ECM's and harness issues. But apart from that nothing too major. My previous experience with Sisu is with 6 cylinder units in MF and Perkins in MF-Landini and McCormick. I also agree with the comments about the Dyna 4 MF, good reliable units and gearbox is very very reliable.
All the best with your hunting.
/ Which engine would you choose? #18
Interesting Robert, I looked at a Landini Vision 95 with perkins engine in it on Friday. 20 speed tranny with dual power and power reverser, very nice machine, mostly massey under the skin I'm told.
My Massey dealer is also a Landini dealer. He gave me literature on the Landini fruit and vineyard tractor but Massey literature on a 100 horse field tractor. I know he didn't give me literature on the Massey vineyard tractor because Massey is in between models right now so he didn't have anything to offer just yet. I don't know if I asked about the Landini in that size. I will ask Saturday though as they are having an open house and are suppose to have a bunch of tractors on hand so I can look them over. I only hope they have a discount on tillage parts that day as I want to fix up my 4-14 MF 82 plow and the bearings alone will cost me $100. I just spent $200 today to repair the International Super Chief 3-14 and don't want to spend too much more on plows:(
I do know I told him I prefered the Massey Ferguson over the Landini because I didn't want people to think I bought a new tractor from my local New Holland dealer (I think you know why). They said they would paint it any color I wanted if I bought it though:) (but I like blue the best:rolleyes: )
Thanks for the reply, I know Sisu has a great reputation which is why Agco wanted Valtra (just for Sisu). I think I would be happy with either motor as my tillage work isn't too intense. I was told the 4 cylinder would be better for haying work while the 6 cylinder would be better suited for my tillage work. Since I hay around 100 acres a year and till around 20 I think the 4 cylinder would be the better choice if I go with the Massey.
I did like the idea of the longer wheelbase on the 6 cylinder as I broke my back and the longer the tractor will help smooth out bumps (as well as the air suspension seat). But the difference is only around 5-6" if I recall so it isn't a drastic difference. When the time comes for me to decide I will definitely want to try the Massey as I have heard a lot of good feedback on Massey tranny.
I will say I love looking for new tractors but I dislike paying for them:(
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
