kentrodngun said:
I'll beat that dog one last time.
No offense Bob, I actually agree with you and respect your input and knowledge, but using strategically accurate estimates for my last go round:
18' trailer (I own one) is 1750lbs
Tractor + FEL is roughly 3800 lbs
Loaded tires another 500 lbs
Fuel (7 gal tank) about another 50 lbs
Chains & binders another 200 lbs (might be high)
Backhoe approx 1000 lbs (might be high depending on model)
I think he'd only carry one implement + tractor & FEL at a time. However, my total above is 7300 so you are correct that it exceeds the 7000 limit.
Ken, no offense taken, but I prefer to beat dead horses rather than dogs!
As for weights, you said your trailer is 1750#, I estimated 1800 for an 18' trailer so I am pretty darn close. Now I can also offer up my 14' trailer that weighs over 1600# and suggest that mine is built heavier than yours and if he owns an 18' trailer that is build like mine, it will likely weigh 2000#. Neither you, nor I know what he owns, so I had to use an estimate that I figured was fair. I suggested 1800#.
As for the rest of the weights, a CK25/30 TLB is rougly 5350# using your weights. Add another 200# for chains and binders. Weight is now 5550#. Add trailer weight of 1750# and I will agree we are at 7300#.
- No professional landscaper can afford to tow overwweight on a regular basis and expect his equipment trailer to hold up.
- No professional can risk his insurance rates and get caught towing over weight.
- No professional can risk the tickets & fines of towing overweight.
- Add to that, it is stupid and dangerous.
But, since he is a professional landscaper, then I will also suggest that he will have other things on that trailer. If you go back and look at what I wrote, I suggested that. Heck, just toss a 5-gallon "Gatorade" cooler on there and the weight goes up ~50#. Toss a chain saw, weed wacker (
and 5 gallons of gas), then toss on some shovels, rakes, etc. and it is not unreasonable to assume there is a total of 250# to 500# of "stuff" added to the trailer. I presumed it to be 400# and stated so in my first post.
Also, while it is likely that he may not carry everything every time he tows, it is also likely that he will occasionally do that. And while you might argue that he only will carry 1 implement, I'd suggest that he ultimately will end up buying more implements and probably will be adding a box blade and a landscape rake very quickly to his implement pile. I'd also suggest that he may well carry 2 or 3 implements at any given time. Lawn preparation could easily use a tiller, box blade and landscape rake on the same day. There are many other examples when he may be doing several tasks and not want to make multiple trips (
nor is it cost effective) simply to transport implements.
Consequently, depending on what he carries, the implement weights, etc he could easily be right where I said he would be.
So I will go back and suggest that if he needs implements sized like those in his 1st post, his maximum tractor would be a 30hp Kubota
B7800 which weighs more than a CK20 but far less than a CK25/30.
If he needs a tractor sized for the implements he has chosen (
55" tiller and 52" rotary cutter) then he should not go less than a 25hp tractor (
my opinion based on my experince, equipement uses, various soil conditons that I have operated in, etc) and he would be better off with something like a Farmall DX26 or NH TC26DA, both weight slightly less than a CK20.
If he uses a 48" cutter (
preferably a medium duty unit instead of the lightweight unit he picked) and a 48" tiller, then the CK20 would be an excellent choice and would work with his trailer.
Certainly there are other options as well, these are just examples of configurations that will work, other brands certainly have tractors that will fit the requirements.
CK20 = 15.5 PTO HP
- Typical recommendations for a rotary cutter are 4 to 5 horsepower per 12" of cutter. 3hp per 12" limits tasks to light duty cutting.
- The tiller he picked is larger than the tiller I use. I use it with both 24hp and 30hp tractors. In loam or sand, the 24hp easily spins the tiller to full depth on the first pass. In heavy clay, the 30hp can barely run the 50" tiller I operate and easily bogs the engine on the 24hp tractor (even on the second pass).
Maybe its just me, but if this is a commercial operator, then
TIME = MONEY. WASTE = LOST PROFIT.
Commercial users have typically face all sorts of conditions, heavy & light duty. Larger implements require more power. I fear the CK20, with the implement sizes he chose, is a bad match for commerical use. Might be OK for home users who can control their operating conditions, but not suitable for a business user. JMHO
That said, all the folks who might suggest "
he could just take 1/2 passes" with the implements would be also be suggesting that:
- the implements are in fact too large
- he will have to slow down and waste time (lose profit) -or-
- he will have to use part of the tool and waste time (lose profit)
