Lots of photos at the "External links" at the bottom of the Wikipedia article.
Doodlebug tractor - Wikipedia, the free encyclopedia
Bruce
Bruce
Another point: Weight. A lot of traction, also known as tractive effort, is a function of weight.
You can have all the torque and horsepower you need, but if you can't hook it to the ground with a combination of wheel size, tread pattern and weight, all you'll get is wheel spin.
You also need to consider the effect of the rear suspension. Tractors have no suspension other than the cushioning effect of pneumatic tires. If you have leaf springs, some of the torque that you're trying to put on the ground to do work will result in twisting the rear end in the spring mounts and "winding up" the springs.
At the least, you'll have wheel hop. At the worst, you break the springs, universal joints or driveshaft.
None of the above is a "deal killer" you just need to think about matching your load to the amount of usable tractive effort you can generate without breaking things.
Hello everyone. I'm new to this forum and just wanted a bit of insight from all those that are experienced. I own a 2002 Wiley's jeep and was wondering if I could modify it and run it as a tractor. I saw a couple of videos of people in the US doing it and also found out that Wiley's themselves made a tractor jeep long ago. According to some basic calculations I did, if I add a secondary reduction after the gearbox the jeep should be able to produce enough traction. So is this possible ? Or am I missing something here a. And any idea why something like this doesn't already exist ? A car or jeep that can be used to plough and till.
Thanks in advance for your response.
Check his location.
Like these?A neighbor has one as /pine pictured. 3pt hitch & pto & 4WD. Very cool. I don't think you'll do much plowing with a 2WD. I remember years ago as a kid seeing jeeps used on the highways mowing. Seen them set up as ditch diggers with a rear "ditch witch" style chain, and a few other "arrangements" that were odd. I think that someone posted one here that had a loader/backhoe set up a year or so ago.
