mguitas
Super Member
- Joined
- Aug 22, 2011
- Messages
- 8,080
- Location
- Schuylkill County Pennsylvania
- Tractor
- Massey Ferguson 1423 Hydrostat
I was using Rotella , but not I got Amsoil only a half of a mile drive from my house. Can't beat that.
I run Rotella T6 synthetic 5w-40 year round
Coby
No, I was understanding that starting a cold diesel tractor was made easier by moving the steering wheel. Know nothing about "faster warming"..
I've tried it, and it "seems" to help but then my Deere 4300 has always fired right up with no hesitation since new 18 years ago.
I have no idea how this could possibly help start a tractor. Maybe I am missing something though... anyone have a good reasonable explaination why this would work. I have heard of turning headlights on for a few seconds before starting a car to get the current flowing out of the battery.
Perhaps if power steering is using electric it is doing the same thing.
vince, I'm OK with T6. I'll buy whichever oil is cheaper: they're both good oils for what I need. Oil consumption was just a minor footnote: I record when I put oil in my cars between oil changes (10k mile intervals), writing down mileage of course; one day I'll look to parse my data and see if there really is any difference (just for now it's been kind of my observation).
Anyone running turbo-charged engines are going to have some oil loss/consumption. It's the nature of turbos. And, diesels, also the nature of the beasts (cold engines). As I mention, I'm running turbo diesel VWs and my oil change intervals are 10k miles (I could go farther; lab tests tell me that), so it's guaranteed that I'll use oil.
X2, It is recommended for diesel and gasoline engines. I run it in everything I own, boat, motorcycle, lawnmowers, cars, truck and of course tractors. It keeps me from having to keep several oil varieties and weights around.I run Rotella T6 synthetic 5w-40 year round
I run 0-40 if it needs to cold start. My tractor runs 15-40 because it sits in my heated shop always and the 15-40 is what I have a bunch of.
I'd run 0-40 for sure if you needed to start in the cold temps. Its the same oil, just flows better cold which is what you want anyway.
I've always been under the assumption that Diesel oils don't have "friction modifiers" in them to make the oil more slippery like a full synthetic car oil does. Diesels need this, but car engines benefit from the friction modifiers in them by reducing the friction.
I run car oil in my cars because of this.
My new to me son n law has a 4240 and always has 15-40 wt oil in his tractor during the winter. We get temps down in the teens and minus degs in the part of the country where we live. It seems every year he has issues with the tractor starting during the lower temps. I have been helping him with this issue and I have convinced him to keep a Battery tender on the bats and that has helped.
My question is would 10-30 wt make a improvement with his situation and what about a 5- 40 synthetic as well and he could run the 5-40 all summer also and not half to change oil every season. I stopped using 15-40 in my 7.3 Ford PS and opted to use 10-30 and experienced good results and according to what I read the 15-40 shears down to a 30 wt anyway after some time in the engine.
I'm curious what others are doing in this situation,,,,,and before I forget to add the Bats. and voltage output are good and up to date.
Oil weight is a contributing factor in engine wear, not in starting issues. Several things you can do to help the tractor start like it is 60 degrees.
1. Block heater- warms the block so there is less heat loss to the block during starting, equals faster combustion.
2. battery blanket/warmer - keeps the power level up. An 80 watt blanket does wonders.
3. engine oil heater - warm oil is easier flowing and gets to lubricating faster. I use a 150W adhesive heating pad on bottom of the oil pan.
As far as oil, as others have stated, 5W-40 T6 full syn is what I have chosen to run year-round.
Actually, oils DO have an effect on starting in cold conditions. That's the entire point of the 5w and 0w oils. I was reminded of this when starting my log splitter that had been sitting (we've been hitting near teens of late); not until I'd yanked on the starter nearly 3 dozen times (rapidly, because I KNEW.....
