Workshop Insullation Question
/ Workshop Insullation Question #1
John861
SE Michigan
Ford 861
I've built a new garage/tractor workshop, 24x40 stick built. The structure is built on two exposed courses of cinder block (which are on a 48" poured concrete foundation). The sill plate of the walls leaves just a bit of the cinder block holes exposed.
So the question is, should I attempt to put some sort of insulation inside the cinder block holes? Great Stuff foam would seem ideal, although cost prohibitive. The shop will be heated so I'd like to minimize heat loss.
Any thoughts?
-John
/ Workshop Insullation Question #2
The top course of block should have been solid, so this would not happen.
I have had to "deal" with this in the past for customers. If you have the room to do so, try these:
Option #1- stuff the block with some newspaper so only about an inch or two of "hole" is left, and foam.
Option #2- Stuff the block as above, and top with mortar.
Option #3- Go to a sheet metal shop, and have them shear some galvanized sheet metal. Slip under the wall, and use construction adhesive to glue it down to the block. You can have them bend like a 1/2" lip on the inside edge, for a more finished look.
All work well.
/ Workshop Insullation Question #3
You can pour the voids in the CMU's with Perlite and then grout the top solid. You could even use styrofoam peanuts and grout the top. Short of doing that, like has been mentioned just wad up newspaper and grout the top. Perlite will give you the best R-value in CMU's.
/ Workshop Insullation Question #4
If you fill the cores by pouring in expanded perlite, you will increase the R-value from about R-1.6 to R-5.9 (assuming 8" 2-core medium-weight blocks). That R-value is for the whole wall, not just the perlite (so it includes the loss from the webbing in the blocks).
Call your local masonry supply companies to get availability/price on perlite insulation. It's sometimes sold in 4 cubic foot bags.
Below I've tried to estimate how much perlite you'd need so you can figure your cost. Skip to the examples at the bottom for the short answer.
The general formula for 8" 2-core blocks is
volume_in_cubic_feet = perimeter_in_feet x wall_height_in_feet x 0.26
Don't forget to subtract the width of doors from your perimeter.
The perimeter of your 24' x 40' building is
24+40+24+40-(door_widths)
or
128' - (door widths).
Your 16" high walls are 1.33' tall.
The surface area of your wall in square feet is
1.33' x (128' - door_widths_in_feet)
The volume in cubic feet of the cores of your 8" 2-core blocks is approximately
wall_surface_area x 0.26
or
1.33' x (128' - door_widths_in_feet) x 0.26
As an example, if you have a 12' garage door and a 3' wide walk-in
door, and the perimeter of your building is 128', then the volume of
the cores for your blocks is
1.33' x (128' - 15') x 0.26 = 39 cubic feet of perlite = 10 four-cu-ft bags.
As another example, if you have two 12' garage doors and a 3' wide walk-in
1.33' x (128' - 27') x 0.26 = 35 cubic feet of perlite = 9 four-cu-ft bags.
/ Workshop Insullation Question #5
Goofy question. If the blocks are hollow, how did you attach the sill plate to the block ?
/ Workshop Insullation Question #6
Willl has a good point.
Perhaps they only filled the occasional core where they put in sill bolts/sill straps?
Great info. I'll look around for some perlite.
Oh, and the some of the holes are filled with concrete to hold straps for the sill plate.
Thanks guys!
/ Workshop Insullation Question #8
John861 said:
some perlite.
Another place to find perlite would be in the 'gardening' section. Right next to the potting soil.
/ Workshop Insullation Question #9
I looked everywhere for perlite/vermiculite. I missed the obvious place...my local concrete block supplier. I bought it in burlap type 4cu ft bags for $9.95 a bag. It pours VERY easily even with a small exposed hole. It may be worth your while to make some sort of "funnel" specific for you space since the stuff pours out very easily and you could easily spill half of it on the floor. It also settles very little.
I agree that I would get the perlite then either foam the fill space or preferrably mortor it so it lasts and is a neat job.
Good luck.
Peter
/ Workshop Insullation Question #10
Ok, well I guess the question now is do you want too insulate it, or Just seal the
holes?
I don't think I would spend a lot of money insulating it, if it is not living space.
holes?
Only a portion of the garage will be heated, so I may not insulate the entire perimeter. But the workshop side will be fully insulated so I can keep it above freezing through the winter without spending a fortune.
/ Workshop Insullation Question #12
I don't have any experience with block walls and homes, so this is a bit of a suprise to me. R 1.6 sure seems low, in fact, it's the part that really suprises me. Are you sure this is correct? Then adding that perlite, another thing I've never heard of, will bring it up to almost an R 6. Double pained windows are around an R 5, give or take a few tenths either way.
I'm wondering what that perlite costs and if it's worth the expense. Foam sheets will give you an R 5 just glued to a wall. They are cheap and real easy to use. Add sheerock or OSB to the inside of the wall and you go up to R6 and have a nice interior wall. More foam, more insulation, and that's not counting what you get from that hollow block wall.
Of course, framing the interior of the wall with 2x4 studs and fiberglass insulation will bring it up to an R13. I've heard this is very common in cement basements, but again, it's not something I'm very familiar with and find this to be an interesting topic
Eddie
/ Workshop Insullation Question #13
I guess then, I would go with the perlite, if I could do it without spending a lot, and seal the top.
Considering you planned to heat this area, you could have opted for a more energy efficient design.
You should have eliminated the block from being part of the inside walls in this area.
I would not loose any sleep over it now though, either way, its only 2 courses. And its at the bottom.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
(2) UNUSED 25X10.00-12 TIRES W/ 4 LUG RIMS (A64280)
(2) UNUSED...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
