Yanmar 3_30 3.70 star(s) (3)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Yanmar 3_30.
Under 25 HP Tractors
About the Yanmar 3_30
Yanmar 3_30 Discussions (7)
Here are the most recent 3_30 topics from our community.
  1. S
    Yanmar F16d tractor stuck in Reverse gear
    Hello, new here I Have a Yanmar F16D tractor that i have had for a few years now that has worked pretty good for me. today I was driving it and went to change from reverse to 2nd gear and it jus...
  2. R
    Anyone need filters for a Yanmar F16D?
    I was cleaning out one of my old sheds and came across a stockpile of filters that I had acquired over the years for my Yanmar F16D. I parted ways with the F16D a couple of years ago and forgot...
  3. R
    yanmar f16d hydraulic filter
    Can someone help me find original hydraulic filter number for yanmar F16d? I found that for yanmar F14-F15 you can use filter by number 194250-48310, but I can't find the filter number for my...
  4. R
    Yanmar F16D Steering Column/Gearbox
    I posted a few weeks ago about a noise coming from my steering equipment - well, it gave up yesterday. Luckily, I was mowing and I broke down about 20 feet from my workshop! I took everything...
  5. J
    Yanmar F16d ring and pinion
    Help please new member. I purchased yanmar with bad rear pinion gears.I have had problems finding part.Any help would be appreciated. Thank you, jarrod
  6. R
    Yanmar f16d valve adjustment
    Hi, Could someone please tell me what the valve clearance should be on this engine? I just replaced the head gasket, everything looks good except the valves look like they have way too much gap...
  7. A
    Yanmar F16D Intake and Exhaust Valve settings
    Does anyone know the proper valve lash settings for a F16D?
[ad placeholder]
User Reviews (3)
Read what TractorByNet members think about the Yanmar 3_30 Subcompact Tractor
5
0 %
4
67 %
3
33 %
2
0 %
1
0 %
4.00 star(s)
reggis
3_30 Yanmar
Yanmar
Model Year: 0
Pros: 123.
Cons: 123.
4.00 star(s)
Jeff K.
3_30 Yanmar
Yanmar F16D - It Is What It Is
Model Year: 1977
I needed a small compact tractor to work in my yard, about 2 acres. This is a grey market Yanmar so it is tough to find parts for them - although if you really search you can find them, they just might be a bit more expensive than you would like. For instance I replaced all 4 tires on my tractor last year and had to have them special ordered - probably about a 10-15% premium. Not ridiculous considering I was able to get them locally and have them installed. I have a loader (800 lb capacity), Howse 4 ft scraper w/rippers, and a 4 ft tandem disk. I use all 3 attachments fairly regularly with the disk the least. I did reverse my rear tires to help widen the stance of this narrow tractor, but I do have issues with the disk and scraper hitting the tires when turning too sharp. The small tractor is nice to get into tight places - the 4WD makes it a real workhorse and it will sit and dig itself into a hole it has so much torque/power. My unit does have a PTO on it but I have not used it much. The previous owner did for mowing. It seems to work fine. The motor has been great - I can let this tractor sit for months and when I want to use it - amazingly it starts right up. No issues. My ground is flat as a board so no issues with slopes/rollover. The tractor does not have a ROPS on it.
Pros: Low cost in comparison to other compact models, powerful for it's size.
Cons: Hard to get parts. Everything is in Korean/Japanese.
Photo Uploads:
3.00 star(s)
Anonymous Poster
3_30 Yanmar
Tough to Find Parts For
Model Year: 0
Yanmar F16D, with Allied Loader, 3pt hitch, Rankin 4ft mower. I use this for moving earth, manure, and mowing. When it works, it's a good tractor, but it was grey market, no ROPS. The wheel base is too narrow, and on hilly terrain (like mine) it's easy to tip over, which I did once - rolled totally over upside down. The problem is that when anything needs replacing - side link, seat, ignition, even a back tire, it's hard to find anyone to work on it, and even harder to find parts. It sat for over a year once while I tried to find a back tire to fit - had to order from China. Slightly underpowered on PTO. Planning to sell or trade soon for Kubota, Holland or Deere.
Pros: Price. Good performance for the price.
Cons: Low power PTO, no ROPS, very hard to find parts.
Yanmar 3_30 Owner Pages
View owner pages to see photos, customization and comments about member-owner Yanmar 3_30s
Yanmar 3_30 Community Rankings
#272 user rating of 731 Under 25 HP Tractors items
#507 Viewed of 731 Under 25 HP Tractors items
#147 discussed of 731 Under 25 HP Tractors items
#2103 user rating of 19625 items overall
#4368 Viewed of 19625 items overall
#972 discussed of 19625 items overall
#14 Ranking of Most-OwnerPages in 19625 items overall
