Buying 5' disk harrow?
   / Buying 5' disk harrow? #1
framer
Gold Member
Central Kansas
B7800
Considering buying 5' three point disk.for b7800 dealer thought
That was good for it to pull. What to think? Will use it on some ground
i took off about 8" dirt has trash and rock in it. Did not want tear up the
tiller.And have some areas in 4 acres that rough spots holes. Dirt good Ks.
black clay soil.Hard in summer works pretty good when moist.Do think running
Disk then dragging till smooth will work with plowing. Some bermuda fescue
grasses.Thanks for the advise Framer.
   / Buying 5' disk harrow? #2
Yes a 5' disk will work just fine behind your B7800.
   / Buying 5' disk harrow? #3
I use a 5.5 foot disk behind my B2710, no problem. Haven't used it since I got my tiller, but plan to use it again in a couple of months.
Has any one made 3 point drag harrow. Wondering if it works as well pull
pull behind.Have small areas to smooth out it would be nice to lift and back up.
Thanks Framer.
   / Buying 5' disk harrow? #5
Thanks Framer.
Here's one. Kinda pricey both just to get a drag harrow and the part to make it a 3 point but you might get some ideas for building one.
http://www.wingfields.com/dragharrow.htm
   / Buying 5' disk harrow? #6
Check out the formulas here for HP requirements. You can determine HP required to pull a certain implement or HP required to till a certain acreage in a specified time. Dont know how old this data is but it should at least be a good estimate
http://www.tifton.uga.edu/eng/Publications/farm tractor.pdf
   / Buying 5' disk harrow? #7
When we farmed, we used to use a 3-pt. 6-row row-disc (hipper) and pull a drag behind it to know down rows for planting. It was literally a rectangle frame with 1-1/4" pipe with drag teeth welded facing down. It was pretty heavy to spread 20+ feet but worked well. You may not be able to back up but you could disk and drag at the same time.
Thanks for the replies.Wingfield drags to expensive.Think i will make one
similar to kfbeal with teeth slanted.Picked up 5' cimarron disk made in Atwood
Ks. today used it on B7800 did well i thought. Dealer had it in inventory since
06 said take it home buy it for $800.00 if you like it. I think he knows me buy
know. Haven'T return nothing yet.New price in 08 $1,175.00 now Looks like it
will be staying.Thanks again best advice BTN forums.Framer
   / Buying 5' disk harrow? #9
Thanks for the replies.Wingfield drags to expensive.Framer
Yes they are expensive but they work well. I have a 8 ft standard harrow with the 3pt frame.
John
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2001 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2001 FORD F-350 XL...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
1968 Fiat Allis 10c Dozer (A56438)
1968 Fiat Allis...
1604 (A57192)
1604 (A57192)
