3R Home and Barn Project
   / 3R Home and Barn Project #1,221
He left the house one day with a weedeater, a roll of string, and a can of gas. He hasn't been seen since, but the hills and valleys all look really nice and trimmed.;):D
   / 3R Home and Barn Project #1,222
Hiking that Appalachian Trail ?
I hope not and of course I hope is is OK.
   / 3R Home and Barn Project #1,223
I think that Rob got tired of being retired and went back to work.
   / 3R Home and Barn Project #1,224
I'm SURE there was a post from him yesterday, a box blade thread IIRC.
   / 3R Home and Barn Project #1,225
Jim,
That's funny, but I would expect Rob to be more of the "Have Box Blade, will travel" type of guy. He just took off on his tractor one day and is out fixing everyone's road, one ranch at a time!!! :D:D:D
Eddie
Holly mackerel, you guys are great!!
Since we've been up here just doing "regular chores", I didn't think there was too much to be posting about. But I see you guys all care and are very considerate. Thank you for asking...
Here's an update.
Yes, I've been very busy around the ranch.
The Chickens are BIG now, but we are still waiting for the first batch of eggs to arrive. That should be real soon now.
I got some Actos Blue Sequoia trees planted and got the watering system going to them. They are like Coastal Redwoods are should grow nicely in this area as long as there is water for them. We also got the entire garden watering system complete. Did a lot of trenching and ran over 1200 feet of PVC to feed each of the orchard trees and garden beds.
We got another ballast tank and booster pump to use the 5,500 gallon water reservoir to irrigate with.
That will continue to freshen up the water in the tank as we use it and it doesn't affect the house water system. We have a valve that can throw the water from that tank to the house system in case our well pump breaks down. So now we will have both water and pressure for the house in case of a break down. In the mean time we use it to irrigate the garden and also the steep slope behind the home.
We also got gutters put on the home and decided to get those copper rain chains.
I still need to have the rain chains come down to the ground into collection box or drum so I can channel the run off down the hillside. But here are some photos of that. You can also see a couple of the Redwood trees we planted in the fore ground.
The latest thing I've been working on is making some furniture out of the Oak logs.
I will post some photos after I get them loaded up. I made some simple stools for the rear deck patio. They are tall enough so you can see over the railing. They are very rustic and were easy to make. Since then, I took on a more ambitious project of making a living room coffee table. I took a huge Oak stump and sliced it in half. My plan is to butt up the trunk halves together with roots sticking out on each end and also down for legs.
I'll have to post photos for you to see all that.
Thanks again fellas, you sure made me feel better.
Rob-
   / 3R Home and Barn Project #1,228
Rob,
That sounds real intresting. I've been thinking about doing something like that with a stump and the roots, but haven't come up with anything that I liked. I like your idea. Is this something that you've seen? or did you just think of it?
In my case, I'm wanting to do both a mantel and some other furniture out of Cedar Stumps. I've made a few shelves, and really like to sand and shape the wood so it's smooth with all it's random contours.
I'm looking forward to seeing your table.
Eddie
Hi Eddie,
Thanks for the comments.
I have seen tables made of stumps before but never one split in half like I am (attempting) to do. I have some photos of the project but will need some guidance on finishing the top.
Here you can see the stumps I have lying around and how I split the big stump in half with a chain saw. I cut the trunk off pretty short and planed those ends to but them up together. I blocked up the two halves to see how they lined up.
Then I pocketed out on each side so I could use (5) 1/2-13 all thread to bolts and glue the 2 halves together. I made a tool to chisel out the pocket so (3) of the bolts could be as near the table top as possible for maximum strength in case the wood split or broke.
Rob-
   / 3R Home and Barn Project #1,230
Very nice Rob! Have you ever seen or tried one of those wood carving
wheels you use on your angle grinder? The teeth look like chainsaw teeth
and allow you to "carve" away lots of wood quickly.
2014 Ram 1500 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 Crew...
2016 Chevrolet Sonic LS Hatchback (A55758)
2016 Chevrolet...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A55788)
2012 Ford F-550...
