B3200
   / B3200 #1
8x56mn
rock stream,ny
B2150
OK I'm looking into swaping my B2150 with FEL for a B3200 that has a backhoe w/thumb and FEL. I paid 6000.00, 8 years ago with a MMM that I have since sold and put a woods FEL on it. I have many other attatchments that I am keeping. The dealer estimating a swap for 18-19 without seeing my machine or 28.5 clean deal. The problem is it's a HST and I'm not sold on that feature after hearing about all the problems with HST. What are you guys thoughts in the price and HST. The 3200 does not come with a gear shift and would have to go to the L.
   / B3200 #2
What are the problems with the HST? I don't see a whole lot of threads that would be negative about them. I for one never had any issues. If you want to stay with Kubota the L2800 is not a lot larger and it does come in a gear model. JD 790 / Massey 1528 and New Holland TC30 (whatever is the current model #) also are very good gear tractors that are comparable size and HP.
   / B3200 #3
HST is the best thing to happen to compact tractors since the front end loader !
   / B3200 #4
HST problems? What HST problems? I'm perfectly content with mine.
   / B3200 #5
HST problems? I am like the rest..
I have compared my L3400 to the L2550 a relative has in a gear model..
and I would never have a gear model for what I do with mine..
Please expound on the HST issues.
J
   / B3200 #6
I agree with everyone else not many problems with the HST. The price for the new tractor seems pretty high. You don't say where you are located. but I would check out Used Kubota Tractors Used Kubota Tractors of North Carolina - Carver Equipment in Dunn (NC): used Kubota tractors, used rtv, for sale, mower, backhoe, loader, bx, accessories, bx24, 900, generator, rtv 900, engines, b7100, equipment, excavator, bx23, b21, bx2350, b7800, . You can get alot more equipment for less money. New or used. Carver lists plenty of Demos with new financing rates. I know from personal experience Barlows will sell you a new or used tractor for a price thats hard to beat and will take you trade as well. I bought from Barlows new and I'm 400 miles away. Good Luck.
   / B3200 #7
Ditto! Ditto! Ditto! All 9 of mine have been HST and would never have a gear unless they didn't make an HST. If I was just plowing fields I might have a gear to save the money. With FEL if your going to use it the HST is so much better, faster and easier. Rarely will you find someone that has HST and goes to gear unless it's for money reasons. You'll find many, many that go from gear to HST and never go back. There are always exceptions to every rule but some people also believe no man ever landed on the moon.:) Ask your dealer about these rare claimed HST problems. Ask your dealer about resale of a gear vs HST. Ask your dealer about percentage of HST vs gear sales. We are in an automatic transmission society and you holdouts need to join us!!:D
   / B3200
Well for sure there are 5 who love the HST. have you read through the hundreds of threads talking about all the issues around HST, starting with the rediculous cost of the 50 hour sevice, or the runaway tractors or the the neck jerking when you change directions, or the sticking pedals just to name but a few. Common people there are issues. :confused:
   / B3200 #9
You asked for opinions and we told you not to worry about the HST.
   / B3200 #10
Your just getting some bad sampling there. The 50 Hour service is only about $50 cheaper for a gear drive tractor. The neck jerking is limited to 1 series tractor, thats it... and most people are not even aware its a problem until someone tells them that it is.
HST's are much more reliable and easier to operate than their clutch and gear counterparts. Under 50 Hp, its almost all thats sold any more.
   / B3200 #11
Let me take a second here:
50 hour service cost-- yep cost me $150 for the fluids and filters. Can someone post what the gear cost?
Runaway tractor-- If I knock a gear outa gear it might runaway too..
sticking pedals-- lube it up.
end result-
If ANYONE wanted to be a pessimist they could find problems with everything and anything..
NOTHING on this earth is perfect. EVERYTHING has problems. YES somethings have more problems than others, it all depends on your attitude, and perspective.
the things you brought up are not things I have experienced..
BUT let me say this: HST 50 hour maintenace- even at $400 is a deal to me..
If I can do in 2 hours with my HST what my neighbor on his Gear did in 3 hours.. that extra hour there and every other time savings will quickly be worth more than the cost of several hundred dollars. not sure about you but every hour I save on a project due to better/different equipment is an hour I can use for something else.. As a businessman time is money and as a parent time is worth more than money- I want that time...
anyway--- SOAP box yeilded.....
J
   / B3200 #12
Thanks to Messicks-- I missed that reply before I posted..
$50 for a delta in the 50 hour maintenace.. wow-
---See the savings comment in my earlier post--
How much is an hour of your time worth?
multiple that times every time you use the loaded in tight places for 2 or 3 hour runs.. x 10 years...
neck jerk--
missed that too---
If I am going full out forward, and then slam the pedal on the rear
yep I might have that problem and an expensive bill at the dealer..
not sure how to figured that savings....
anyway--- I am with Messicks don't worry-- get the HST..
Good luck and remember pictures count!
J
   / B3200
Well gee, just forget I even asked, won't again that's for sure.
   / B3200 #14
You asked for opinions from members on this forum. We gave them to you based on our actual experience. Our experience disputes your "claims" of all the problems. We with HST's have not experienced all these problems and I've never seen many posts claiming all these problems with the HST that you don't want. If you just want agreement to an eronious idea then post that you want agreement and not actual information and experienced opinions. Then you won't get your feeling hurt again, maybe.:) No, you probably will.
   / B3200 #15
I bought my B2320 HST last year and have been very happy with it.
This particular model does have the gear option. Like you I had questions regarding HST versus gear. Initially I planned to go with with the gear but after talking to an experienced tractor owner I went with the HST instead. He also advised me to buy the FEL and go with a rotary cutter instead of the MM. All three of his opinions have been dead on. My point is, you are doing the smart thing by asking questions. No matter what you decide you will end up making a more informed decision whatever it turns out to be.
All the best,
Dennis
   / B3200 #16
The 50hr service is really a mute point on a decision like this. I did mine myself for under $100. 3 Fiters, gallon on Diesel engine oil and ~ a gallon of Super UDT to replace what I lost when I replaced the two filters on the hyro. You wouldnt buy a auto or manual trans in you car based on this would you?
Good luck in your search.
   / B3200
Well you asked what problems. Perhaps you all should read the thread below mine BX2200, talking about their HST problems, but then again I'm just looking for someone to agree with my concern I guess;)
   / B3200 #18
Your right! I'm now seeing all of the problems you mention. You need to buy the geared tractor, I believe it will be the best one for you. The geared tractors never tear up and last forever. No one has ever had a problem with a geared tractor. That's the one to buy for happiness forever. GO GEARED!!!
   / B3200 #19
I'll just say that I am not a fan of automatic transmissions. My trucks and my car are all stick shifted and I won't willingly buy a car with auto trans.
That said, I own a Kubota B7800 with HST and wouldn't have it any other way. The thing is tough and I've worked it in ways I probably shouldn't. It's never been a problem although it does have a way of lurching into full low range engagement that sometimes pisses me off a little. Still, I've really come to like the thing.
I also have a stickshift Jinma (couldn't pass the deal). With 13 forward speeds it's really quite a workhorse but simply having to shift makes every tractor movement more work for me and slower by far than if I do same work with the Kubota.
   / B3200
OK look I was looking for a cross section of opinions and only got pro HST You all know that there are problems with both. You would have to be in a state of denial if you think that HST have no or very few issues. For the most part I agree if you have a toy tractor HST is great, but for the the realy day in and day out ones I believe the gear is better. I'm not trying to sway anyone and I realy don't care what you own, if your happy with it great. Don't put me down for asking a question.:(
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A59230)
Pallet of...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
